Old 10-18-2010
TejasSailer is on a distinguished road
Source for Resin Proof tape
Years ago when doing gelcoat repair, I used cellophane to cover and smooth-out the repair during curing. The linked article below suggests using resin proof tape. Resin proof tape seems to be available in UK. However, I am unable to find a source of resin proof tape in the US. Does anyone know if Scotch Sealing Tape is essentially a resin proof tape or have other suggestions for acquiring resin proof tape?
Boatworks: Sailboat Maintenance ... - Google Books
Tools, Tapes, Resin Proof Tape, - CFS Fibreglass Supplies
Old 10-18-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Tejas,
I've this stuff with good results. I think I paid less than $10 for a pad at Michaels (an arts and crafts supply chain store here in the US).
Dura-Lar
It's a 5 mil plastic sheet (similar to acetate) that comes 9" x 12", 25 sheets to a pad. Very easy to cut down to whatever size you need to cover your spot repairs. Lay it over the repair and smooth with a squeegie. It'll really cut down on the amount of wet sanding you'll need to do.
Only drawback is that at 5 mil thickness, it doesn't handle curves very well (at least, not without a fair amount of tape.)
For larger repairs, I'd recommend spraying and coating with PVA.
Cheers.
Old 10-18-2010
hellosailor's Avatar
Tejas, contact 3M by email or toll-free number directly, and they can give you technical information on any product they make--globally. And usually on the same one phone call. Odds are, they make the tape and they can tell you where to obtain it.
Old 10-18-2010
mitiempo's Avatar
PorFin
If you mean 5 millimeters that is almost 1/4". It is available in different thicknesses. See below.
Brian
Old 10-18-2010
PorFin's Avatar
Señor Member
Originally Posted by mitiempo View Post
PorFin
Brian,
No, no mistake. I didn't mean 5mm, I meant 5 mil (as in 5/1,000 of an inch). Thanks for double check, though.
Old 10-18-2010
mitiempo's Avatar
Sorry, I am from a country that tried to be metric.
Brian
Old 10-19-2010
PorFin's Avatar
Señor Member
Hey, at least you guys are still officially metric. We're the Neanderthals still clinging to Imperial measurements. We gave metrics a quarter-hearted attempt back in the 70's, and quickly gave up since it was "too hard and confusing..." (which is actually a more polite and self-denying way of saying we were too mentally lazy to adopt it.) I think the killer was temperatures -- folks just couldn't get their heads around the fact that 25*C was a really nice day outside
Old 10-19-2010
mitiempo's Avatar
Imperial is better. See this link for the reasons and an interesting story.
Pieces of String Too Short to Save
Brian
Old 10-19-2010
I'd second imperial units as being simpler...
Old 10-19-2010
PorFin's Avatar
Señor Member
OK, I'm justifiably chastised...
For the record, I'm not advocating switching to the metric system -- I'm happy with the Imperial. I just wish that I didn't have to keep a complete set of both Imperial and metric wrenches around to work on engines, cars, etc...
I am alive Scott has proof.. artbyjody Pacific Northwest & Alaska 5 02-14-2010 09:43 PM
epoxy resin vs. polyester resin for hole repair leecarlson Gear & Maintenance 19 05-10-2008 07:35 AM
All the Proof You'll Ever Need RAGNAR Off Topic 1 01-24-2008 10:29 AM
Re: Spam Proof NewsReader Mass Bay Sailors 0 06-14-2006 10:15 AM
Spam Proof NewsReader Mass Bay Sailors 0 06-13-2006 10:15 PM
