Old 10-19-2010
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Thru-hull valves: Ball or Gate?
That is the question. What's the best to use?
I'm looking to replace the sink drain (currently a 3/4" gate valve) and the head inlet (a 3/4" ball valve) with new ball valves.. and then fit new something-or-other to the 1-1/2" cockpit drains.
Is it just personal preference - or is one definitely superior to the other??
Thanks,
Cameron
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 10-19-2010
St Anna's Avatar
St Anna is on a distinguished road
Ball valves in my view - get rid of all gate valves. Especially in hoses that may not really ever be closed - like the cockpit drains.
Old 10-19-2010
marksaviation is on a distinguished road
gate valves belong in swimming pool fittings not on any yacht
Old 10-19-2010
CaptainForce's Avatar
Gate valves fail by remaining stuck in the open or closed position. This is a rare trait for a ball valve. Definitely, select the ball valve.
Old 10-19-2010
PorFin's Avatar
Seńor Member
PorFin is on a distinguished road
Yes, ball valves are far superior to gate valves (at least on a boat).
A couple of other reasons to go with ball valves:
o You can tell at a glance whether they are open or closed.
o You can close them from fully open to fully closed in one quick flick of the wrist.
Old 10-19-2010
Ball valves are definitely the way to go. Along with what Porfin and CF said, they're also far easier to maintain....Do be sure to get marine grade ones though, since the brass ball used on the hardware store variety ones can rot out pretty quickly in salt water and leave your boat ready to sink...
Old 10-19-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
One more vote for Ball Valves.
I am having a have a hard time thinking of ANY application where gate valves are superior to ball valves. I swap ball valves out at every possible opportunity. NONE on my swimming pool, none on any plumbing that I work on (kitchen, bathroom).
The only application that I can think of, and this is only because we're all used to seeing them here, is an outside faucet.
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 10-19-2010
and even there, a lot of them are being replaced by ball valves..
Old 10-19-2010
JohnRPollard's Avatar
Moderator
Cameron,
This is a no brainer. Ball valves all the way.
Gate valves are not allowed in new boat construction here in North America, and haven't been allowed for decades. Insurance companies usually require that any existing gate valves be replaced with proper seacocks/ball valves as a condition of insurability.
Old 10-19-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Cameron this is way easier than cored hull or nay. Have a ball.
As the mighty JRP says...no brainer.
Lubing Ball Valves (tip/trick) Maine Sail Gear & Maintenance 8 11-30-2010 05:46 AM
blanking gate valves aquagee Gear & Maintenance 2 04-26-2009 12:03 PM
can I use bronze ball valves w/plastic thru hulls? nightowle Gear & Maintenance 6 04-20-2009 02:16 PM
Gate valves and why we don't use them... sailboy21 Gear & Maintenance 28 11-12-2008 10:55 PM
Gate valves, with scary photo pmoyer Gear & Maintenance 61 04-11-2007 12:55 PM
