Old 10-19-2010
Walt352 is on a distinguished road
Battery Charger
I have a 1984 C30 with two battery's and would like to add a permanent charger to the boat while at the marina. If I have a TV,DVD,lights ect ect going at the same time what size would it take to keep the battery's charged. The boat has shore power with ac outlets but no converter or would a converter be better. If anyone could offer some help it would be greatly appreciated.
Old 10-19-2010
What size are your batteries. You should generally size a battery charger to suit the batteries you've got. Too large a charger and you're likely to fry the batteries more easily. Too small a charger and it'll take a long time to fully charge them, if ever.
IOTA makes a pretty decent charger with a three-stage regulator and are far more economical than a lot of the other brands.
Old 10-19-2010
Sailingdog I will have to get to the boat and look at the size. I can get my hands on a ProMariner Pro 1000 it is a 10 amp 2 bank 3- stage charger but I did not know if it would do the job for what I wanted.
Old 10-19-2010
Usually, if you have wet cell batteries, you want a charger sized to about 20-25% of the battery bank 20-hour amp-hour rating. So, if you had a battery bank of two 6 VDC T105 golf-cart batteries, you'd want a 45-50 amp charger, since the bank would be rated at 225 amp-hours. A 10 amp charger is really a bit small for most applications. It'd be a good maintenance charger, but that's about it.
Battery Charger doesn't ereiss Electrical Systems 10 05-10-2010 12:58 PM
Battery Charger wchevron Gear & Maintenance 2 12-26-2008 08:03 AM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 08:30 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
Battery Charger? motorbortniker Gear & Maintenance 6 06-23-2006 02:02 PM
