10-20-2010
Termite Fodder
Originally Posted by mitiempo
I'm planning on adding a large single drain through the transom next haulout. My cockpit sole is 8" above the waterline. I will probably keep if to only a slight downward slope as I am keeping my 2 existing drains below the waterline. It will be as close to center as my outboard rudder allows. I will install a spring loaded flap over the exit to stop water splashing in. I am doing it because my existing drains are too slow.
MIT, for the boat in the pic you posted, I'd suggest TWO smaller, say 3" dia, straight-through above-water line transom drains, one in each corner of the cockpit, exiting either side of the rudder with flaps - not one large one.
Two reasons: (a) when the boat is heeled, the lower one does all the work, but if the boat is flat and the cockpit floods you're using both (twice the area) and (b) it's harder for two drains to get blocked than one.
You'll see this setup on many small racing yachts and fast sailing dinghies for the reasons above.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
