Old 10-21-2010
sunnyshine is on a distinguished road
Espar D8 Installation
I have a used espar D8 unit that I want to install on my sailboat, but I need all the associated parts (only have the unit itself) and some serious info to do a DIY install. Ocean Option quoted us over $3k for install and I don't think our budget can take that. Any advice, guides, photos, or parts lists? Thanks!
  #2
Old 10-21-2010
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
Which OO? The one in Annapolis is really bad. For Espar (or Webasto) work around Annapolis talk to Annapolis CruisAir.
Read the directions and get the install kit - it is a reasonable DIY job. Be sure to get the drain for the exhaust - it's an extra part.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #3
Old 10-21-2010
It would probably help to say what boat you have as well as where you plan to install it... someone may have installed the Espar D8 on the same boat and might be able to give you some very boat specific help.
  #4
Old 10-22-2010
I talked to both the OO in Annapolis and the one in Newport. I called Annapolis Crusair, but no one technical was in so the receptionist said they'd call me back. I will call again Monday if I don't hear back. I've also called a few other boat yards in our area for quotes.
We plan to install it on a Cal34 in the port lazarette (ours only has a quarterberth on the starboard side) and most likely run the air duct forward on the boat through the top of the port storage shelves.
  #5
Old 10-22-2010
Mermaid Hunter
Your installation plan looks reasonable for a Cal 34 based on Googling the arrangements.
Annapolis Cruisair is a family business, two brothers and their sons are out working most of the time. The three ladies in the office are pretty knowledgeable, but the do know what they don't know. Brian's (the head guy) son is the best Espar guy.
I'll be happy to share my OO horror stories (apparently I learn slowly) if you are interested, but I'd rather not type it all out again. PM me your phone number and I'll give you a call to share my tales of woe.
S/V Auspicious
AuspiciousWorks.com
  #6
Old 10-23-2010
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
I found that OO options in Rhode Island were very knowledgeable and did a great job - but they certainly were not cheap!. I would imagine that your installation would be pretty straightforward (ours was quite complex) so I would tackle it after checking out a few installs to get some ideas. A D8 will give you tons of heat in a 34 footer.
Big change in our status. we have decided that we cannot safely (in my mind) leave South Africa this season allowing for the time needed for my hand to recover from its injury. All typing is right-handed at this point. We will leave Ainia in SA and head north and west in the early southern summer ~Oct/Nov?
You can check OnAinia.blogspot.com for updates on our travels whenever I get around to it.
You may post attachments
You may edit your posts
Espar heating system Norstar Pacific Seacraft 6 12-21-2010 11:04 AM
Espar vs Webasto heaters ebreeden Gear & Maintenance 7 11-27-2009 09:11 AM
Espar Heaters and Co/No2 NicknewGuy Gear & Maintenance 3 05-03-2008 07:01 PM
Webasto vs. Espar labatt Gear & Maintenance 8 02-18-2007 12:15 PM
ESPAR heat AGP Gear & Maintenance 3 03-21-2005 03:50 PM
SEO by vBSEO 3.6.1
