Old 10-21-2010
SabrinaKS is on a distinguished road
Lewmar Traveler Help
We have Lewmar travelers on our staysail and the main. The rubber cushioning on both sides of the cars is breaking down. It has turned brittle and crumbles if you touch it. I am not even sure what that "cushioning" is officially called. This is happening on both main and staysail traveler - all cars. Does anyone know, can this cushioning be replaced? Is there a fix? Prefer to fix vs getting new gear $$. I checked the Lewmar web site but didn't see much to help with this so I am turning to Sailnet.
Lewmar Traveler Help-breakdown-traveler-bumper-005.jpg   Lewmar Traveler Help-breakdown-traveler-bumper-004.jpg
~~_/)~~_/)~~_/)~~
Sabrina
McVay Minuet 19 "Riot" & Caliber 40 "Honey Ryder"
Lake Perry KS & East Coast
Old 10-21-2010
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
If you're handy w/ power tools, some body shop "rubber squeegees" (used for the red lead type putty) or a snubber for a trailer spring or winch should be easy to cut to fit that w/ a band saw. Just use a thin piece of wood for a backing while cutting it.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 10-21-2010
Hhhuumm? Might need more details. Red lead type? Snubber for trailer spring - like RV or boat trailer?
~~_/)~~_/)~~_/)~~
Sabrina
Old 10-21-2010
You could probably fit a standard round rubber bumper to each screw on each side... they're not very expensive and fitting them would be relatively simple.
There's no real need to have a custom Lewmar part for that other than possible aesthetics. These things are used for feet on a lot of different pieces of equipment as well as bumpers for things like doors and the like.
Old 10-21-2010
jrd22's Avatar
Courtney the Dancer
I agree with Mac, you could probably make new ones out of a piece of EPDM rubber.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 10-21-2010
Why make something when you can buy something for very little money that will serve the same purpose? Much easier to deal with and you can buy spares to start out with.
Old 10-21-2010
Oooh. Good ideas. We also have a plastics manufacturer in town. Maybe they have some rubber that we could use. They often have interesting scraps that we have put to use on our previous boat. Thanks. Keep the ideas coming if you have more.
~~_/)~~_/)~~_/)~~
Sabrina
Old 10-21-2010
MacGyverRI's Avatar
The red putty they put over body filler, they use a rubber squeegee to apply it, usually around 2" x 4" x 1/4"+ thick.
Yes, like on a RV or boat trailer, kinda like a square or pointed block of semi soft rubber. Find one a bit bigger and cut it down to fit.
Old 10-21-2010
Irrationally Exuberant
arf145 is on a distinguished road
If it were me, I'd be doing Sailingdogs solution. Bumpers like that might be found at Home Depot. Online, McMaster-Carr would certainly have them.
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 10-21-2010
jrd22's Avatar
Courtney the Dancer
SD- your stock bumper idea is fine, I meant if he wanted them to look like the originals he could just cut a piece of rubber mat to shape.
John
SV Laurie Anne
Lewmar maintenance lisasailor Gear & Maintenance 10 04-05-2011 11:39 AM
Which pawls for a Lewmar #10? jarcher Gear & Maintenance 2 08-22-2010 09:49 PM
Lewmar 46-ST TexLex Gear & Maintenance 7 03-13-2009 05:35 PM
Lewmar yachtmeander Gear & Maintenance 3 07-21-2008 11:58 AM
Lewmar WInches ross99 Gear & Maintenance 1 03-06-2004 03:17 AM
