Old 10-21-2010
Pub911 is on a distinguished road
Hot water smells baaaaaad!
Just the hot water. I have an Isotemp water heater, and the water from it smells like sufur or similar. Acrid. Really awful. I thought i remembered seeing a thread on this but I searched and couldn't find it. Help!
Thank you!
  #2
Old 10-21-2010
ToppDogg is on a distinguished road
You are smelling Hydrogen sulfide, either from the use of well water or you have a bacteria in your hot water tank.
  #3
Old 10-21-2010
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
Our hot water line was old and ran through the bildge and stunk every time we turned it on. It was picking up a bad smell from the bilge water.
Irwin Citation 34
  #4
Old 10-21-2010
so what to do?
  #5
Old 10-22-2010
October Moon B43
MJBrown is on a distinguished road
You can also get a build up inside the tank. Flush it thoroughly. You may need to do a couple of times.
  #6
Old 10-22-2010
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
Rik - fix the hole in the hose.
Pub - add chlorine to your hot water system, and then flush out the tank.
It is also possible that the IsoTemp Hot Water Heater has a Magnesium anode in it which is reacting poorly with the minerals in your water system. Replace the anode, preferably with a zinc anode, and treat per above. Also, consider filling your freshwater tanks elsewhere.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #7
Old 10-22-2010
RichH's Avatar
RichH will become famous soon enough
Odor in hot water systems is usually indicative that the magnesium anode inside the heater has 'depleated' .... replace (or add) the magnesium anode.
Do NOT substitute the magnesium anode with a zinc anode.
  #8
Old 10-22-2010
Ahh.. Rich beat me to it.. I was going to suggest it was the anode too. If it was bacteria from filling the tank, the cold water would smell as well, not as strongly, but it would. If it is only the hot water, it is likely the anode more than bacteria.
  #9
Old 10-22-2010
eherlihy's Avatar
Arrgh...
Looking into the Magnesium vs Zinc thing. What I know is that Magnesium anodes can react with sulphates in the water to produce Hydrogen Sulphate (aka stink). I believe that this is less of an issue with zinc.
Digging deeper; I looked through the Isotemp website for user manuals. Here is the link: Isotemp Slim & Basic
What I found after skimming a couple of them is that there is NO reference to the anode for an IsoTemp Water Heater. This leads me to conclude that there is no anode! ("There is no spoon.")
Theory: there is bacteria in your fresh water tank, and the temp (>160°F) is killing them in the water heater. As the bacteria decompose in your HW tank, excuse me... , other bacteria are producing hydrogen sulfide.
Possible solution: Chlorinate your entire freshwater system, and then flush with CLEAN water from a different source than you usually use.
I have used swimming pool shock for my (new to me) boat, which had sat unused with full water tanks all summer long. Swimming pool shock is (calcium hypochlorate). Others prefer bleach (sodium hypochlorate) to chlorinate the system. If you want my rationale, follow the links that I provided. What ever you use, hit it hard, and flush it out several times before using.
Good luck!
  #10
Old 10-23-2010
merc2dogs is on a distinguished road
The last is what worked for me. My old water tank would get smelly every now and then. I would let water out, pour a gallon of household bleach into it, refill it and let it sit for a few hours, then flush and refill, No more smell.
I have heard of the anode causing smelly water, but it's never been the source in any case I've dealt with.
You may post attachments
You may edit your posts
Alcohol Stove "Smells" alofns Gear & Maintenance 36 01-12-2011 09:31 PM
Chlorine Dioxide to combat mildew smells saillavie38 Gear & Maintenance 2 12-16-2009 04:13 AM
Teak Smells? Dink2 Gear & Maintenance 6 12-03-2009 09:00 PM
Fresh Water cooling water dirty brown sailak Gear & Maintenance 17 07-31-2009 11:52 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
SEO by vBSEO 3.6.1
