Old 10-22-2010
ramminjammin is on a distinguished road
blank canvas
I have an old wooden sailboat , cold molded , it has a yanmar diesel with a 12 volt altenator.
the boat is not wired and does not have any electronics , lighting, navagation gear etc
I use hurricane lamps for lighting , plus battery powered ones
I plan to use the boat for coastal cruising with the odd 300 mile blue water passage.
I would like to keep things simple and modern
What is the system I could use that could combine
radio,radar, chart plotting , autopilot epirb beacon, internet access, telephone ?
is there a product that combines everything or most of these ?
o
Old 10-22-2010
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
If you really want to keep it simple. Get them all, but seperately units. That way if one fails everything else is still working. Some you can combine, but I can't imagine all these units being in one........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 10-22-2010
thanks
yes that is good advise to have separate systems
there is some new radio system that is better than the old vhf ?
it gives gps emergency loaction ?
Old 10-22-2010
olson34 is on a distinguished road
Lightbulb
Check into the newer SH CPV350.
Less clutter can be a very good thing. If you worry about redundancy just carry a spare handheld vhf and a small portable gps to give you lat and lon.
This is not everything on your wish list, but will have most of the vital stuff.
Then add an iPhone.
Old 10-22-2010
QuickMick's Avatar
QuickMick is on a distinguished road
they have some neat stuff:
NMEA 2000 Networking | LOWRANCE | Marine Electronics
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-22-2010
I would keep things simple... as suggested previously. Having a single device that does multiple functions is probably a bad idea, since it becomes a serious single point of failure. While, it is common to combine some functions, like GPS, Chartplotter and RADAR into a single unit, I would recommend keeping some functions separate for safety's sake.
  • VHF—get a DSC-capable Class D unit. Make sure to get your MMSI and enter into the unit and wire it to the GPS.
  • GPS/Chartplotter/Radar—I like the Garmin GPS units, as I think they have the best UI and their charts are pretty good too. The 3206, though discontinued, is an excellent unit and one of the smallest that supports the Garmin 18HD RADAR. It can be bought for about $700 or so, and the Garmin 18 HD can be bought for about $1000, giving you a decent chartplotter, radar and GPS in a single "box" for under $2000.
  • Autopilot—this depends on whether the boat is tiller or wheel steered, as well as the displacement of the boat. If the boat is tiller steered, you have a few choices, but the least expensive is an integrated tillerpilot, like the ST2000+. These units are less than $500 or so and can be installed in an afternoon if you're not a complete klutz. For wheel-steered boats, the least expensive option is a wheelpilot. .
  • EPIRB—is generally bought by itself. Defender.com had a Category II EPIRB with integrated GPS for about $400 recently, so might be well worth checking.
  • Satellite Phone—Right now the only good game in town is Iridium. Globalstar has been having network issues, which I don't think have been fully resolved yet.
  • Internet Access—Basically not really doable from the high seas without a very expensive satellite phone setup. Closer to shore you have two options: 1) A cellular-based data plan and device—cellphone or aircard; 2)an amplified WiFi setup, like the one I describe here.
You'll need a decent size battery bank and probably want a battery bank monitor to keep an eye on it. You'll probably also want some passive charging capability, like solar, which I wrote about here.
To keep your energy usage down, I'd highly recommend going with LED-based lights. For running lights, I like the Aquasignal Series 32 LED lights. These are better than replacement LED bulbs in that they're purpose designed and will probably last longer than LED replacement bulbs. Also, they are USCG certified, unlike most replacement bulbs. For cabin lights, I like the Sensibulbs, which can be used in a variety of fixtures.
o
Old 10-27-2010
thanks for the great advise !
Old 10-28-2010
QuickMick's Avatar
good sat phone article here:
Search Results | Yachting Magazine
Quinn McColly
Yacht Broker
Depth Finder goes blank for long periods caliman Electronics 10 08-02-2010 04:08 PM
Nav Station Blank Plate labatt Gear & Maintenance 10 11-03-2009 03:25 PM
Canvas Dcneuro Bristol 0 05-31-2009 09:05 AM
Canvas akin_alan Gear & Maintenance 2 01-26-2002 05:04 AM
canvas colors doctorroberth Gear & Maintenance 0 08-21-2001 03:21 PM
