Crazy Looking Socket - Page 2 - SailNet Community
post #11 of 47 Old 10-22-2010
Try using a "face spanner wrench". If not get accurate measurements and buy the correct sized "Spanner Socket" Try someplace like AutoZone, Advance or Napa. Bring measurements with you.
thinplaces is offline
post #12 of 47 Old 10-22-2010
Thanks guys, I need one too, but had no idea where to look. There are numerous adjustables on ebay
WanderingStar is offline
post #13 of 47 Old 10-22-2010
The problem with the adjustable ones is that they can't work on anything that isn't right at the surface. If the nut is recessed at all or in a position where you can't get easy, fairly clear access to it, the adjustable ones won't generally work. They need to be basically parallel to the face of the nut to work properly.
sailingdog is offline
post #14 of 47 Old 10-22-2010
Maine Member
BELLATRIX1965's Avatar
Close, but not quite!
Originally Posted by F4d3d View Post
Well, I think this is what I'm after. The one in this photo is too large, so it won't work, but I'd like to know what it's called so I can try to track one down that is the right size. Anyone know what this shape of socket is called? And any ideas where I can find one to buy?
The ring around the outside of that tool will not let you engage the pins - sorry! What you are after is a "bearing locknut socket - 4 pin" like this:
OTC OTC7270A Bearing Locknut Socket Fw 4 Ear Ranger & Bronco
Size will be tricky, but try a local bearing supply house - they will know what you are after. Good luck!
BELLATRIX1965 is offline
post #15 of 47 Old 10-22-2010
Basically that's the beastie I was describing making from a socket above...
post #16 of 47 Old 10-22-2010
Does anyone know the name of the socket shown in posts 8 & 14? I need one like that so it will tighten the nut while depressing the spider legged locking spring under it.
post #17 of 47 Old 10-22-2010 Thread Starter
F4d3d's Avatar
@BELLATRIX1965 - Great! That looks like it's the one. I'll try to track one down, which should be easier now that I know what it's called.
@SD - Thanks for the input.
@WanderingStar - the photo I posted was of something used on a 4X4 of some sort, so you can probably find one at an auto parts supply place. Or maybe at Mac Tools or Snap-on or something along those lines.
I'll let you guys know if/where I find one.
Cheers, Russ
F4d3d is offline
post #18 of 47 Old 10-22-2010
bljones's Avatar
It's also known as a transmission gear socket:
Tools Transmission Tools Tools Tools Tool Transmission Tools Tools Tool
TOOL Page (¯`·.¸(¯`·.¸ ZDMAK SPECIAL TOOL STORE ¸.·´¯)¸.·´¯)
bljones is offline
post #19 of 47 Old 10-22-2010 Thread Starter
F4d3d's Avatar
They don't come cheap! $76 - $110 USD, crazy!
F4d3d is offline
post #20 of 47 Old 10-22-2010
bljones's Avatar
Which is why most of us use a cold chisel and a mallet. It's sorta like going home with the only unattached chick in a biker bar at last call; it ain't pretty, but it works.
bljones is offline
12 Volt Euro Socket dave6330 Gear & Maintenance 15 07-09-2008 11:04 AM
Tell me I'm crazy... MARRSY Living Aboard 40 03-28-2008 12:02 AM
old autohelm electrical socket jimmiebuchanan Gear & Maintenance 1 02-06-2008 10:40 AM
IS this crazy? Tspringer Chartering 11 01-11-2008 06:37 PM
