Crazy Looking Socket - Page 3 - SailNet Community
post #21 of 47 Old 10-22-2010
Originally Posted by F4d3d View Post
They don't come cheap! $76 - $110 USD, crazy!
Having a machine shop cut a socket, which only costs about $20, is probably going to end up about the same price, but far more useful, since it will still probably work as a socket still. If you have a friend with a bridgeport milling machine, they can probably do the job in under an hour.
sailingdog is offline
post #22 of 47 Old 10-22-2010
bljones's Avatar
If you're relatively handy and careful, and own an angle grinder, you can probably cut the socket yourself.
However, if you don't feel like DIYing it, contrary to the namebrand advice dispensed by SD above, there are likely many other milling machines besides Bridgeport capable of handling this task.
bljones is offline
post #23 of 47 Old 10-22-2010 Thread Starter
F4d3d's Avatar
@SD, I'll keep that in mind. My problem is that I'm flying to México on Sunday, so I need to find this tomorrow. It may be quicker to find one that I don't need to mess around with, but if I can't find a 1 1/4" Bearing Locknut Socket, I may go with having a regular socket machined to work. Again, the time constraints add to the problem - especially since tomorrow is the weekend. :P
F4d3d is offline
post #24 of 47 Old 10-22-2010
Buy a socket that fits the piece and then carry it with you. You can probably find a machine shop that can mill/cut it down in Mexico. On second thought....buy two of the sockets, in case they screw up the first one.
post #25 of 47 Old 10-23-2010
Handsome devil
Stillraining's Avatar
Yep its a wheel bearing socket
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #26 of 47 Old 10-23-2010
Señor Member
PorFin's Avatar
Originally Posted by bljones View Post
Which is why most of us use a cold chisel and a mallet. It's sorta like going home with the only unattached chick in a biker bar at last call; it ain't pretty, but it works.
Along the same line of thought, use a brass drift pin/bar instead of a cold chisel. The brass is strong enough to transmit the energy to the target, but soft enough to keep from doing a lot of damage to the lock ring. If the lock ring is on there tight, or somewhat siezed, a good cold chisel will start taking chunks of the lock ring off.
Brass drift pins are relatively cheap -- I just found this set of four on E-Bay for $17
PorFin is offline
post #27 of 47 Old 10-23-2010 Thread Starter
F4d3d's Avatar
This is what I ended up doing in the end, after searching about 10 auto parts stores without success. I sure hope someone down in México can machine this baby to work!
F4d3d is offline
post #28 of 47 Old 10-26-2010 Thread Starter
F4d3d's Avatar
Update on SD's method of machining a regular socket: The finished product isn't pretty, but it worked. We took it to a crude looking machine shop here in Guaymas, and the guy managed to craft what we were looking for. Once back at the boat, we did some fine tuning since the "prongs" were slightly wide, and then it worked like a charm. Thanks everyone for your great input and suggestions!
F4d3d is offline
post #29 of 47 Old 10-26-2010
Glad to hear it worked out.
post #30 of 47 Old 10-26-2010
Courtney the Dancer
jrd22's Avatar
Just saw this thread, glad it worked for you Russ.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
12 Volt Euro Socket dave6330 Gear & Maintenance 15 07-09-2008 10:04 AM
Tell me I'm crazy... MARRSY Living Aboard 40 03-27-2008 11:02 PM
old autohelm electrical socket jimmiebuchanan Gear & Maintenance 1 02-06-2008 09:40 AM
IS this crazy? Tspringer Chartering 11 01-11-2008 05:37 PM
