Crazy Looking Socket - Page 5 - SailNet Community
post #41 of 47 Old 10-27-2010
Again, this doesn't work if the nut is recessed at all and will have problems unless you can get the tool flat against the nut.
Originally Posted by cormeum View Post
Google "two prong spanner"
sailingdog is offline
post #42 of 47 Old 10-27-2010
I'm thinking I can make one from a short piece of pipe with the right diameter. I'll drill and tap it to put short hex head machine screws inside to engage the notches. Larger holes at the other end will allow a pry rod to provide torque.
WanderingStar is offline
post #43 of 47 Old 10-28-2010
eherlihy, what is that tool you had in your photo (Crazy Looking Socket I have one in my chart table from the PO - no idea what it is for.
paul323 is offline
post #44 of 47 Old 10-28-2010
The one in your chart table might be for opening deck caps, water or fuel types.
post #45 of 47 Old 10-29-2010
Learning the HARD way...
eherlihy's Avatar
Assuming that you meant this picture; , and not the motorcycle steering bearing wrench.
This is an adjustable deck plate wrench/key. It is a great tool to have.
eherlihy is offline
post #46 of 47 Old 10-29-2010
Thanks guys. Apologies for the brief hijacking. Makes perfect sense; I have the standard 'keys' aboard, so I guess this is just a backup which will fit both diesel and water - probably also for the emergency tiller deck plate - and perhaps provide more leverage when needed. Cool.
paul323 is offline
post #47 of 47 Old 10-29-2010
48' wood S&S yawl
cormeum's Avatar
Based on his pic it appears that it'd work just fine. The prongs extend about 1/4" from the flat. Usually for those nuts it's either a two prong spanner or a chisel and hammer (tap,tap,tap).
I've seen cutting a pipe to fit as well.
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
cormeum is offline
12 Volt Euro Socket dave6330 Gear & Maintenance 15 07-09-2008 10:04 AM
Tell me I'm crazy... MARRSY Living Aboard 40 03-27-2008 11:02 PM
old autohelm electrical socket jimmiebuchanan Gear & Maintenance 1 02-06-2008 09:40 AM
IS this crazy? Tspringer Chartering 11 01-11-2008 05:37 PM
