Old 10-22-2010
mitiempo's Avatar
seagull s**t
Eliminating seagull droppings. New product with an interesting name.
Shitstrip
Brian
Old 10-22-2010
jackdale's Avatar
jackdale will become famous soon enough
Truth in advertising.
You might do the same thing with wire ties.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 10-22-2010
mitiempo's Avatar
Yes, but the name isn't as catchy.
Brian
Old 10-24-2010
bruceyp's Avatar
bruceyp is on a distinguished road
You better use some serious wire-ties for the birds around here. Cormorants and the gulls in this area learn pretty quickly that those wire ties will easily bend. If your intent is to tickle their bellies, have at it. Bird-x plastic spikes are used on spreaders and on the mast heads around here, and even then, the birds can break off some of the spikes, and then flatten the remaining ones. this won't work on pulpits or pushpits, of course.
( the usual disclaimer regarding no affiliation with the Bird-x company)
BP
Old 10-24-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
It won't prevent most of the droppings on my boat, which are the result of low level strafing runs as opposed to surface deposits
Old 10-24-2010
paul323 is on a distinguished road
Seagulls? Hah! I had a heron who decided that my mailsail cover was a good place to hang out. They poop big.
My PO used old CDs on a fishing wire; maybe I should try those.
Old 10-25-2010
QuickMick's Avatar
QuickMick is on a distinguished road
came from amsterdam... some guy in a hashbar had a heck of an epipany...
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-25-2010
Ob-la-di, Ob-la-da :)
Sixpoint is on a distinguished road
I know, right? Each "incident" with a heron looks like someone dumped a half gallon of wet plaster.
Peace,
6P
Old 10-25-2010
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
That's plain horrible. Glad the Heron around here don't seem to be much interested in sailboats, especially mine.
Water is Life
Old 10-26-2010
ereiss is on a distinguished road
PoopOff
I find it in pet supply stores where it is used to clean bird cages. Really worked when my sail cover and dodger got bombed by cormorants. FWIW
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
British Seagull nauticalnut Gear & Maintenance 5 11-19-2008 09:01 AM
British Seagull? Dinghy engine advice needed Pamlicotraveler Gear & Maintenance 25 05-21-2007 07:28 AM
