PVC Pipe for a holding tank? - Page 3 - SailNet Community
post #21 of 26 Old 11-10-2010
mitiempo's Avatar
Aquarium through fittings - can you please expand on this.
Brian
mitiempo is offline
post #22 of 26 Old 11-10-2010
Here is my 2 cents on PVC. Based on construction experence, The fittings do not like strain, if they are in a bind they will crack. Pvc swell just slightly when exposed attic temps over 140 degrees. As PVC ages it becomes brittle. Lastly, PVC is can stand no UV light. This applies to all scedules. I have seen air line ran in PVC last 10 years till some bumps them then you have an air leak.
waterdog52 is offline
post #23 of 26 Old 11-10-2010
Originally Posted by YARDPRO View Post
why in the world would you not use white pvc? Pvc is used for municipal water lines all the time? green pipe is used more for drainage and sewer lines.. it is a thinner wall and is more prone to cracking and breaking. there is no difference in smell between the green pipe and others... the green is merely a color used so people can more easily identify the pipe and it's contents in the future... ie. purple pipe for reclaimed non potable water..... same pipe, just a dye used for ID purposed...
Grey conduit is also the same PVC with a dye so it can be identified ad an electrical conduit.
any pvc would work fine, i like the schedule 80 idea as it is stronger. any of the drainage pipe (green, etc) would be a thin wall and more prone to cracking or chafe than the thicker 80, although the volumes would be reduced...
I think just about all Grey PVC has UV stabilizer in it. that is why you can use it for stand pipes and conduit. I cant say Ive seen Grey PVC over 4".
Not sure about the other colors. but I would steer clear of white.
robotopdx is offline
post #24 of 26 Old 11-11-2010
Schedule 80 is overkill. Schedule 40 would be fine. I would be more worried about sloshing. You could get an amazing amount of backpressure in a rough sea. This would be magnified by the diameter and the length of the pipe. Think of it like a blowhole.
Bayfield 29
jskrypek is offline
post #25 of 26 Old 11-11-2010
It won't get much UV light in the bilge.
WanderingStar is offline
post #26 of 26 Old 11-11-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
Surely anyone heading offshore would void their tanks and go to direct pumpout at the first opportunity ? Holding tanks are, after all only for inshore use.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Dye in holding tank davidpm Gear & Maintenance 5 09-27-2009 12:05 PM
Poly holding tank pipe thread seal surftom Gear & Maintenance 9 06-23-2008 02:55 PM
Holding tank DLM Gear & Maintenance 11 12-06-2007 06:51 AM
Holding Tank Scubado Gear & Maintenance 14 04-01-2004 11:24 AM
