Old 10-22-2010
tkawika is on a distinguished road
Furuno 1731 questions??
I just purchased a 1972 35 Coronado Center Cockpit. I am planning a minor overhaul with the paint and interior. I am also upgrading the electronics. I found someone selling a "New Condition" Furuno 1731 w/Dome and mounts for what sounds like a great price (under a $1000). I have searched high and low and I haven't been able to find anything in that price range. Is this a good deal? Are they better units? Thank you in advance..
Old 10-22-2010
olson34 is on a distinguished road
Thumbs up
Product Detail - 1731
Link to Furuno, about this model.
FWIW, I have a 1715, and at least three friends have the similar 1623, and we all like them a lot.
If you call (or email) to Furuno USA, they are located in the Pacific NW (Camas, WA) and are very helpful folk to talk to.
L
Old 10-23-2010
L
Thank you for the quick response. Have you had any issues with the CRT? Is a LCD unit any better?
Old 10-23-2010
jrd22's Avatar
Courtney the Dancer
I much prefer the CRT if you have the space for it, although the new LCD's are very good now (maybe better in some ways). If you can power the unit up you should be able to check total hours on it (consult the manual for that model). IIRC the magnetron is good for about 3000 hrs. Good luck with it, Furuno makes the best radar as far as I'm concerned.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 10-25-2010
I am leaning against this unit. The unit itself was in great condition, but the size of the 24inch Dome and the size of the display unit was much larger than I expected. I wanted to mount the unit in the cockpit area but the depth of the unit would prevent a clean installation. Also, I was worried the dome would interfere with tacking or the jib. Any comments.
Furuno instruments brak Electronics 11 11-16-2010 02:39 PM
Furuno Fax30 klubko Gear & Maintenance 0 03-02-2009 07:07 PM
Cut Furuno GPS cable by mistake - Splice questions!!? Northeaster Gear & Maintenance 14 08-13-2008 08:10 PM
Need help with Furuno FS 1503 SSB dm567 Gear & Maintenance 0 11-24-2007 02:35 PM
ray marine vs furuno kimberlite Gear & Maintenance 5 02-17-2002 02:06 PM
