Old 10-24-2010
Walter
walterzoy is on a distinguished road
Prop Speed Propeller treatment question
Has anyone used Prop Speed propeller treatment to keep barnacles off of the prop and shaft? Nothing seems to keep my prop clean and free of marine growth. Does this stuff really work? It is VERY VERY expensive - but so is paying divers or marina lift-out fees!
A marina near Baltimore is offering a free application of Prop Speed when you have your boat hauled out for winter storage.
They charge $75.00 to clean and prep the prop and they will apply the PropSpeed for free.
Considering how expensive PropSpeed is and the fact that I would have to sand or wire brush the prop even if I bought the stuff, it sounds like I would only be out $75.00 if the stuff does not work.
Walter - Catalina 30
Baltimore - Patapsco River
Old 10-24-2010
ASA and PSIA Instructor
Try Pettit zinc coat barnacle barrier, it has always worked for me.
Old 10-24-2010
skipgundlach is on a distinguished road
When I haul in the spring, I will apply another coat of Prop Speed.
For more than 2 years it kept my prop clean. I'm having to scrape it now, because it's no longer there, but for the first two years, it slung everything just as it was supposed to. As it aged, all it took was a swipe with a 3M light pad.
I wouldn't use anything else, because I don't haul frequently...
YMMV but I'm VERY happy with it.
L8R
Skip
Morgan 461 #2
SV Flying Pig KI4MPC
See our galleries at Web-Folio -- Your Portfolio on the Web!
Follow us at Flying Pig Log | Google Groups and/or
TheFlyingPigLog : Morgan 461 Hull #2, Flying Pig
"Believe me, my young friend, there is *nothing*-absolutely nothing-half so
much worth doing as simply messing, messing-about-in-boats; messing about in
boats-or *with* boats.
In or out of 'em, it doesn't matter. Nothing seems really to matter, that's
the charm of it.
Whether you get away, or whether you don't; whether you arrive at your
destination or whether you reach somewhere else, or whether you never get
anywhere at all, you're always busy, and you never do anything in
particular; and when you've done it there's always something else to do, and
you can do it if you like, but you'd much better not."
Old 10-24-2010
billyruffn's Avatar
billyruffn will become famous soon enough
I've used it for a couple of seasons. In northern waters it worked very well. In the Caribbean it wasn't quite as effective, but was still much better than my previous treatment -- nothing!
I've seen props of big power boats that are very clean on hauling....my luck wasn't as good, but I attribute some of that to the application. I think the application last year was imperfect -- the two part primer has to be followed immediately by the one part final coat. The yard that applied it assigned one guy to the job and he wasn't working at light speed. I'll give it another try this year and will do the application myself with plenty of help so that the final coat goes on quick!
The deal the yard is offering sounds pretty good to me. My guess is that it will save you a dive or two. Go for it.
Old 10-24-2010
Walter
PropSpeed
Thanks everyone for the help with my Propspeed question.
Is the Pettit paint nothing more than old fashioned “Cold Galvanizing” zinc-rich paint?
If so, you can buy zinc spray paint at Walmart, with no need to buy the high priced marine brand? Or does the marine brand have a more water resistant vehicle allowing it to adhere to the underwater gear better?
Considering the expense of travelift haul-outs – it looks like PropSpeed is the better value in the long run because everyone is saying it lasts about 2 years.
Because my marina is offering a free coating of PropSpeed with winter haul-out and storage, and not one negative reply as to how everyone likes the product – it is a no-brainer – I am going to have my marina apply my free coating of Propspeed to my prop, shaft, and through hulls.
Walter Catalina 30 Baltimore
Old 10-24-2010
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Prop? Yes. Shaft? Dunno.. I guess so.. never checked.. not sure I would myself. Through-hulls? No. Anti-fouling goes on through-hulls.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 10-25-2010
October Moon B43
MJBrown is on a distinguished road
As an option to Prop Speed I used plain lanolin smeared on all the running gear this past spring. We keep the bnoat in Baltimore Inner Harbor and just had a diver clean the bottom. He stated the prop blades were clean without signs of a single barnacle. There were barnacles on the hub of the prop and shaft so I'll add a bit more prior to spring launch. A cheap alternative to Prop Speed.
Old 10-25-2010
St Anna's Avatar
St Anna is on a distinguished road
Yeah I'd agree. Only on the prop. I have used it for years in the tropics. If it applied properly, it is perfect.
Prop Speed sailing320 Sailboat Design and Construction 3 09-22-2008 05:55 PM
Question on fixed prop drag / hull speed Northeaster Gear & Maintenance 5 04-12-2007 07:26 AM
folding prop speed pickup mrkeith Gear & Maintenance 7 01-11-2007 12:48 AM
Propeller Question Scurvy_Dog General Discussion (sailing related) 4 02-19-2003 04:59 PM
Propeller and Speed The Journey Gear & Maintenance 9 09-17-2002 03:25 PM
