Old 10-25-2010
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Removing paint build-up.
Is it unrealistic to expect soda blasting to remove moderate to severe paint build-up on a 42 year old hull?
If not, are there other media blasting methods that would be more effective (ie beads, crushed walnut shell, etc)? Are these other methods typically offered at marinas and boat yards?
S/V Old Shoes
1973 Pearson 30 #255
Old 10-25-2010
ffiill's Avatar
ffiill is on a distinguished road
Random orbital sander works very well-previous owner of my 34 footer did most of this and I am finishing it off.
Not a quick process but so long as you use a fine enough grit it has a really good result.Removing paint build-up.-005.jpg
Old 10-25-2010
tommays's Avatar
I have found the OMC tools rigid razor blade holder i got at Pep-boys
To be the best tool for the job like carving wood it will take a bit of time to work out your technique (angle of attack ) BUT once you do it is fast and leaves the least mess at the LOWEST cost
I have a good vacume sander and even with good paper its slow and very easy to do a golf ball finish when your removing huge amounts of paint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-25-2010
I don't see why sodablasting shouldn't work on your boat.
Old 10-25-2010
rayncyn51 is on a distinguished road
We just had a pretty nasty accumulation of paint blasted off the bottom of our '79 C-30. We are quite happy with the results. She's in a yard over on Kent Island, if you'd care to drive over and have a look. Cost was $1,300 vs. $2,000+ quoted for sanding. There are a couple of people in the area who are top notch. PM me if you want specifics.
Are we there yet?
Old 10-25-2010
tommays's Avatar
The problem with soda is the limited amount of good drivers and the job REALLY depends on there skill
Tommays
Northport NY
Old 10-25-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Do it yourself if you have the time, I used an orbital sander and then longboarded the gelcoat before barrier coating and paint.
If you don't have the time, go to Muller Marine up by you. He'll give you a race ready bottom, but you'll pay for it.
Merit 25 # 764 "Audrey"
Removing paint from Gelcoat lrak Gear & Maintenance 11 11-08-2008 11:29 AM
Paint Build-up or Barrier Coat? cas8100 Gear & Maintenance 29 05-09-2008 11:25 AM
How long in the Ches bay before build up (no paint) zz4gta Gear & Maintenance 7 05-02-2008 09:32 AM
Removing paint Jotun General Discussion (sailing related) 23 11-15-2006 09:47 PM
Removing Bottom Paint Dan Dickison Gear and Maintenance Articles 0 02-23-2001 07:00 PM
