Old 10-26-2010
Incantation is on a distinguished road
yamaha outboard question with video. t9.9elhp motor
YouTube - VID-20101003-00003.3GP
two questions..
as you can see in the video, when i open the throttle, the motor chokes. if i keep turning the throttle it will die. this leads me to believe it's running rich. i checked the plugs and fuel filter and they are ok.. anyone have any idea what's wrong? you can hear it hiss as the throttle is opened..
also, if i open it very slowly or bounce it a bit.. it will sometime get past the choke rpm and operate smoothly.. and above that choke rpm range it operates perfectly..
lastly, what is the mechanism that moves at 0:09 seconds?
any help would be appreciated. i am comfortable working with motors but outboards and carb'd motors aren't really in my range of experience.
thank you
inc
Old 10-27-2010
boomer365's Avatar
boomer365 is on a distinguished road
Hello l have a 9.9 as well.
The Part moving at 9 secs is the Shift linkage.
As for the stalling on acceleration, not sure at all.
Old 10-27-2010
dabnis is on a distinguished road
Incantation,
Sounds like it may be starving for fuel?. If it has set for more than as few
weeks without draining the carb deposits can form partially blocking the
jets. If pulling the choke part way out helps that is probably the case.
If it has a slow speed mixture control you might try richening it up a bit.
Otherwise you might mix up a half and half mixture of gas and Gumout or Berrymans Fuel Additive, run it for a while, let it set for a day or two
and try it again. If that doesn't work you may have to pull the carb
and thoroughly clean it out. If it runs OK at speed under load the filter
is probably OK and there is probably no air leak? I would guess the low
speed jet is partially blocked?
Dabnis
Old 10-27-2010
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Take the carb off and clean it. Also check the diaphragm in the acceleration pump.
Old 10-27-2010
awesome.. thank you gentlemen
Old 10-27-2010
Most likely a plugged jet inside the carb.. some of these are hidden so take care to find them all. Pay attention when you disassemble the carb so you can reassemble it correctly.
If you don't already have one, maybe add an in-line fuel filter for the future.
1984 Fast/Nicholson 345
1987 Yamaha 6 hp dinghy motor won't start nightsky Gear & Maintenance 9 09-25-2010 07:08 PM
Small outboard motor question for the maintenance experts. Northbeach Gear & Maintenance 7 07-19-2008 12:48 AM
outboard motor newbie question calamitas Gear & Maintenance 5 06-08-2007 08:31 AM
No clue re: outboard motor!? Saltwater question! Cony Gear & Maintenance 7 03-13-2004 06:22 PM
Yamaha Outboard? rhbroehl Gear & Maintenance 3 12-13-2001 02:16 PM
