Impeller issues... - SailNet Community
Blogs
Old 10-27-2010
tkawika is on a distinguished road
Impeller issues...
I am looking for a new impeller for my Albin AD-21 Engine... The reason WHY.. enjoy the read... lol.. Any help would be appreciated and than you in advance..
Old 10-27-2010
QuickMick's Avatar
QuickMick is on a distinguished road
it appears that the ad21 may have two impellers? in any case, can you not measure the size of the aperture and buy one (or two) to fit? conversly, it appears that that was a volvo product/so they may make one? just brainstorming, im an a4 man myself.... good luck
these guys might help:
Albin Owners Group • View forum - Albin Maintenance
Raw Water | Marine Engines & Components | Boat Motors and Components
raw water pump items - Get great deals on eBay Motors, Business Industrial items on eBay.com!
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-27-2010
Thanks for the links.. I belong to the Albin group already, but I am checking out the rest. I pulled the impeller last night and its flexible and all the fins are intact. Is there such a thing as being too flexible? I am bringing it to a marine shop to have them find an equivalent.
I am little worried about the "new" rebuilt engine with 84hrs on it. When I purchased it, I had a surveyor come out and he gave me a list of recommendations, but none about the engine. BUT, I should've known better. Bad Me... When I pulled the impeller out the bolts were almost rusted thru.... Oh well, looks like I am going to learn a lot more about an Albin Engine that I wanted too, because the funds are not there for a new engine.
Thank you again..
Old 10-27-2010
QuickMick's Avatar
all fins intact is very good for you, as if they break and go 'down the food chain' they can cause BIG problems. btw, i highly reccomend you pick up a spare or two just to keep onboard. getting to know your engine isnt a bad thing by any means, just a bit of a learning curve. ive got a spare onboard and will check the flexiblity factor out for you but dont know how scientific i can be. IIRC last one i replaced i would rate at 'medium flex' 1=low flex 10=max id rate it at 3 or 4.
this link is failing me but may work for you:
Albin Motor
AHA! This one looks good--the manual:
AD-21 Handbook
Quinn McColly
Yacht Broker
Old 10-27-2010
Thanks again for the links. The handbook was a amazing find. It still leaves a couple of things out. Such as oil type and some other stuff which escape me right now. I have removed the heat exchanger and its an aftermarket job, I think because it doesnt look like anything else in any of the Albin literature. I've uploaded a video on youtube.
EDIT: I Cleaned the Heat Exchanger with wood skewers hooked up to my Hitachi 14.4 Drill, haha it seemed to work just fine and then hooked a pump did a 50/50 mixture with some Barnacle cleaning solution. I found the steps here.
Thanks again. Im still having issues locating the impeller, but still searching..
Old 10-28-2010
oops the video is working yet, but hopefully soon..
Impeller gives out then...smoke.... GaiaOrion Diesel Engine Forum 5 08-07-2010 06:53 PM
Impeller hrs sailrmon Gear & Maintenance 21 08-05-2010 11:45 PM
Impeller question: how often? Pub911 Gear & Maintenance 8 03-31-2010 12:50 AM
Impeller size LinekinBayCD Diesel Engine Forum 2 02-24-2010 06:40 PM
Raw water impeller Hobos Gear & Maintenance 2 09-14-2008 08:10 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
