Old 10-27-2010
raayres18 is on a distinguished road
Valspar top side paint
I looked through the past threads to try to find this but I couldn't find what I was looking for, maybe someone can give some advise? I just bought a 1975 Cape Dory 25 as a project boat to keep me busy. Like the rest of us I want to keep the cost to a minimum. I wondered if anyone used Valspar marine top side paint? I got some at Lowes. very cheap, I am thinking about starting on the inside and see how this paint works. Also should a primer be used first? any thoughts???
Thanks very much, Ray
Old 10-27-2010
mitiempo's Avatar
I've no experience with Valspar but any paint I have seen in its original can has instructions which state if primer is required for different surfaces.
Brian
Old 10-27-2010
tommays's Avatar
I have used valspar exterior paint inside the boat without a problem
The only topside paint i saw at Lowes was the rustolem brand and while low cost there all one part paints with durabilty in line with the cost
How bad is the gelcoat as a lot can be doen with the correct buffing to bring it back
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-27-2010
mitiempo's Avatar
If you can restore the gelcoat to a reasonable condition that would be much better. Once you start painting it will need to be repainted regularly. With a one part like Brightside maybe every 4 or 5 years, longer with a 2 part like Perfection.
Brian
Old 10-29-2010
valspar top sides
The gel is shot. The non skid is worn off in most areas, I'm going to use perfection on the hull and maybe the deck as well? I want to do all the interior storage areas in the valspar to see hot it looks and maybe the rest of the interior as well?
Old 11-01-2010
I stand corrected, it is Rustolium ,not Valspar, I used the primer and it seems to work pretty good?
Old 11-01-2010
cruisingdream is on a distinguished road
are you talking paint for the deck (top sides are side of the boat above the water) one part paints on the deck won't stand up very long
Old 11-12-2010
I was going to use the one part paint for the interior only, and use something like Interlux Perfection for outside?
Oil dripping over the side ? t4li3sin Seamanship 13 05-01-2009 01:41 PM
Flaking bottom paint on 1 side, strip or repaint? FishFinder Gear & Maintenance 4 12-15-2008 09:20 AM
The Dark Side drynoc General Discussion (sailing related) 25 08-08-2008 12:55 PM
Is there anything you would like to see from this side? Giulietta General Discussion (sailing related) 51 02-09-2008 11:23 AM
top side boat paint chuckg5 Gear & Maintenance 22 07-26-2006 09:32 PM
