10-28-2010
Actually, the Spotless Stainless product passivates the stainless steel and helps prevent corrosion from setting in by doing so.
Originally Posted by RichH
All the 'chemicals' mentioned in the above posts *remove* the rust blooms, doesnt stop or reduce the rust.
The 'best' way to prevent 300 series stainless from rusting, etc. is to POLISH it to a mirror-like finish. Thoroughly remove all excess weld 'bead'/irregularities by grinding and flat sanding so that it is precisely FLAT with the surrounding material. For the 'general surface' mirror-polishing by first sanding with successively finer and finer grit paper down to 400-600 grit, then power-buffing with the appropriate buffing compound until the surface looks like a MIRROR will prevent 99.9% of 'rusting'. If you have the $$$ after the previous steps, then send the piece out to be 'electro-polished'. All this is very time/labor and $$$ costly. 300 series Stainless 'rusts' when its surface is 'rough'; remove the roughness by mirror polishing and it wont 'rust'.
The chemical rust removal treatments are faster, easier, and less costly.
