10-30-2010
Don't use lexan or polycarbonate for portlights unless you like having leaks and rebedding ports constantly. Cast Acrylic is the way to go. There's a bunch of really good reasons almost all of the commercially available ports and hatches are made with ACRYLIC. First, it has much better UV and scratch resistance than does Polycarbonate. Second, it has better physical characteristics in terms of dimensional stability. When you hit a piece of polycarbonate, it can distort enough to cause the seal with the sealant to break, and that leads to the port leaking. If strength is such an issue, go with a thicker piece of acrylic.
BTW, you should bed the stuff using Dow Corning 795 Silicone, which is not your average silicone sealant but a silicone structural adhesive designed for holding glazing materials into frames on skyscrapers and such.
