10-28-2010
Some of the newer rule pumps turn on briefly for a few seconds every couple of minutes and measure their power usage, which is higher when pumping than when running dry. If you wire them with reverse polarity, it is possible that the motor runs backward (thus not pumping), but there is sufficient extra power used to make the electronics think that water is being pumped out. Thus, if there is water in the bilge, the pump will run continuously, as none of the water is being removed.
