LED anchor light - Page 2 - SailNet Community
post #11 of 14 Old 10-29-2010
Got this light a few seasons back from Sailors Solutions as part of a gradual conversion to as many LED's as possible. In addition to the low current draw when it is on, it turns itself off at dawn with a photo cell.
LED lighting, soundproof, Sailor's Solutions Inc.
LinekinBayCD is offline
post #12 of 14 Old 10-29-2010
Send a message via Skype™ to oceanscapt
I've not been happy with AquaSignal's water resistance so when my anchor light went out again I decided to try something different.
I installed an LED assembly in a clear plastic container. I ran two wires out the bottom to connect to 12VDC and a lanyard at the top so I could hang it from the shroud or jib sheet. It's more at eye level than the top of the mast, and I hope easier to see. Current draw went way down so if I have another senior moment and leave the anchor light on until noon, the loss isn't excessive. Since the light is easily reached I can maintain it should something go wrong.
I've thought about adding on of those photo sensors that would turn the light off at dawn but at about 0.1A current draw, but decided the cost didn't justify the power loss.
I recently fabricated a second one for the cockpit lighting. I hang it off the bimini frame and plug it into 12VDC in the cockpit. Works well there too.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
oceanscapt is offline
post #13 of 14 Old 10-29-2010
Have a look at the Bebi lights. They are waterproof, so you dont need the plastic container and they have the option of a photo cell
LED Anchor Light-Waterproof & Rugged for Marine RV and Offgrid Use
noelex77 is offline
post #14 of 14 Old 10-29-2010
While the Bebi lights are great, they're not USCG certified, and I'd highly recommend having a USCG certified anchor light.
sailingdog is offline
New anchor light Sanduskysailor Gear & Maintenance 25 04-29-2010 09:53 AM
portable anchor light maestro Gear & Maintenance 24 08-04-2008 01:08 PM
portable anchor light ktwessling Gear & Maintenance 15 08-27-2006 10:51 AM
Anchor light sailor12345 Gear & Maintenance 2 07-23-2002 02:48 AM
Anchor light syrenab General Discussion (sailing related) 1 04-15-2001 06:39 AM
