Going Aloft; Ratchet Block? - SailNet Community
post #1 of 7 Old 10-29-2010 Thread Starter
I pull myself up the mast by first hoisting a double block up with the halyard, the hoisting line runs over that through a single at the bosun chair. I'm getting about 2.7:1 mechanical advantage. The problem is that each time I pull up a ways, I need to reeve the loose part through the lines on the chair to hold it. This is an old method that uses a single becket bend to secure. I can hold it temporarily by gripping all four running parts together. The other hand adjusts the knot. I think I can make this quicker and easier by using a ratchet block on the seat end. Then I can haul away to my work height, and make up the line with both hands while the ratchet holds me in place. Thoughts? Experience?
WanderingStar is offline
post #2 of 7 Old 10-29-2010
QuickMick's Avatar
this looks like a neat doodad:
Petzl*Mini Traxion Self-Racheting Pulley - Rock/Creek
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #3 of 7 Old 10-29-2010
A ratchet block is not the way to go. They're designed to give you more leverage by taking some of the load off of the terminal end of the line, but they're not designed to hold the line by themselves. You'll need something like what QM has pointed out...which is essentially a block with a line jammer/clutch built into the cheekplates.
sailingdog is offline
post #4 of 7 Old 10-29-2010
Send a message via Skype™ to oceanscapt
I've used jumar's for a number of years. They're simple, bulletproof, and very reliable. They also use your leg muscles which for most of us are far stronger than our arms.
Ascender (climbing) - Wikipedia, the free encyclopedia
Of course, nothing beats getting a lift to the top via a windlass or powered winch.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
oceanscapt is offline
post #5 of 7 Old 10-30-2010 Thread Starter
I'm not thinking of using the ratchet block to hold me at the work spot, only to assist in going up. Instead of stopping every yard to adjust a knot, I'll go to the final height and tie off.
Ocean, I've looked at ascenders too. I just can't quite picture the setup. I don't use a winch or windlass as I am working alone.
post #6 of 7 Old 10-30-2010
Courtney the Dancer
jrd22's Avatar
Good idea Wonk, I've been planning on buying two ascenders (hadn't seen a gri gri) but I like your set up better. Thanks.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is online now
post #7 of 7 Old 10-30-2010
Rock Climbing gear
I've done it with this setup ....
http:// www.newtribe.com/documents/tip4.htm
Tie a static line to your halyard and raise to top of mast, so you're not using the ascender on your halyard
and take a look at the ATN Top Climber videos for tips too
RonRelyea is offline
Going Aloft: Lessons Learned WanderingStar Gear & Maintenance 6 10-23-2009 10:28 AM
Going Aloft Solo ? backcreeksailor Gear & Maintenance 15 05-13-2009 09:31 AM
Ratchet Block for Spinnaker Sheets TejasSailer Gear & Maintenance 4 07-12-2006 07:13 AM
Going Aloft Dan Dickison Gear and Maintenance Articles 0 02-25-2002 07:00 PM
