Old 10-29-2010
rmeador is on a distinguished road
powered ventilation for head
I think I really need to get some kind of powered ventilation for my head to keep the humidity at bay when I take a shower aboard. There is a dorade vent in my head, and also a porthole. I'm thinking I should leave the dorade as-is, since it provides air input, and I should add some kind of powered fan to suck air out. Does anyone know of a solar powered vent that would be small enough to install in the porthole? The porthole is probably 4"x10". I can't find a fan of that size. I'd drill a hole right through the plexiglass to mount the fan. Failing that, do you think I should get a bigger fan and mount it through a hole cut in the deck? Ideally, for both of these hypothetical fans, they'd be the type that charge up during the day so they run all night, but that is not a required feature. Thanks!
1979 Gulfstar 37 Laissez Faire
Old 10-29-2010
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Do you have an engine room blower? You could put a second hose in with a grate that can be closed in the head. Doesn't address your desire for solar power but certainly reduces wiring and complexity if you can run a 3 or 4 inch hose easily enough.
Now that I think of it the idea is pretty decent. Hmmm.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 10-29-2010
COOL is on a distinguished road
A Nicro Solar powered vent should do it,
or shower in the cockpit.
Islander 30 II 'COOL'
Old 10-29-2010
SVAuspicious, that's a great idea. Unfortunately, I don't think it will work. My head is up near the V-berth, so it would be a very long run of ducting. I just had an Espar installed and that used 4" ducting all the way to the bow, and it was a tight fit... I doubt I can fit a second run of duct.
COOL, I'd love a Nicro vent, but I think they're too big. The smallest one I've found requires a cutout of 3 3/4". The overall unit must be wider than the hole, so it probably won't fit on my porthole which is about 4" tall.
Old 10-29-2010
Mermaid Hunter
My head is just forward of the engine room at the base of the companionway. Lucky me.
I'm thinking of an exhaust vent for the galley now also. Thanks for getting me thinking!
The Nicro solar vents have a history of fan failures. Do some Google searches before you plunk down your money.
S/V Auspicious
AuspiciousWorks.com
Old 10-29-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Take a look at Breezy Electric ventilator by Air Only Vents
Old 10-29-2010
Allanbc's Avatar
Allanbc is on a distinguished road
I've been thinking of installing a small computer fan in the port light above my galley. It would probably work in the head, too.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 10-29-2010
pdqaltair's Avatar
pdqaltair is on a distinguished road
Perhaps this is close to what you are looking for:
Sail Delmarva: "A Bathroom Fan": or "No Blog Could be Complete Without a Tale of Head Repairs"
One of my easiest projects, were everything fit the first time.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 10-29-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Get a 'good' fan that you can mount permanently in the head, and with the port-light open most of the moisture will exhaust out the portlight...just like in bathroom in a house.
Old 10-30-2010
hellosailor's Avatar
rm-
If you want to use some type of conventional fan (even a 12v computer fan) and be able to "set it and forget it", you can wire it up to your house battery and use a SPRING SWITCH to turn it on. These used to be commonly but it seems like Ace Hardware are the only folks who carry them now, about $20. they're meant for 120VAC but will work just fine on 12VDC.
Used for bathroom fans and heat-o-lators, they are a simple mechanical spring-wound knob. You twist the knob, the switch turns on. As it unwinds and runs down--then the circuit gets turned off. So you can turn it on when you start the shower, and it will turn itself off 20-40-60 minutes later, whatever you set it for.
I'd suggest the 60-mimute model, because one "twist of the wrist" gets you about 20 minutes on that. A full turn gets you 60 minutes.
Helsen 22 12 volt powered keel rbrown77138 Introduce Yourself 1 03-30-2010 09:05 PM
Wave powered boat...(has sails too) artbyjody General Discussion (sailing related) 3 07-25-2008 09:12 PM
Wave Powered !! Freesail99 General Discussion (sailing related) 7 07-14-2008 12:10 AM
Water powered generators rsn48 General Discussion (sailing related) 26 12-18-2007 01:02 PM
gas powered liveaboards... razorseal Living Aboard 11 04-12-2006 02:12 PM
