Originally Posted by Acadia
Hi, I have a 1985 H40 and it's rigged with an inner stay. I don't have a sail for it yet but would like to get one. Only thing puzzling me is that there are no tracks near the mast for the sheet.
Is there a way to use a staysail on the inner stay without adding tracks? I could put a couple of blocks on either side of the mast close to the base but I'm not sure how well that would work.
Do you have a similar setup on a sloop? Where is the track or block located on deck for the sheet?
Thanks
The best way to set up a staysail without tracks is with a HOYT BOOM or clubfoot with vang. This is important for a 'true' self-tacking staysail or to adequately control the staysl shape when the boat is 'off the wind'.
Otherwise to properly control 'twist' in a staysail you will need the exact same arrangement as how you set up 'any' jib/genoa - tracks, etc. that intersect at a 10 degree angle from the boat's centerline and from the tack of the sail to its clew .... PLUS a means to control the fore/aft + in/out (from the centerline) fairlead adjustment of the clew, etc.
Many cutters use an 'across the deck type traveller' but with poor results vs. 'sail twist', especially when the stays'l is trimmed for less than a beat or high close reach; as, without being able to adjust the fairlead angle a staysail when flown from a close reach all the way down to DDW will usually *always* be open/flogging at the head, grossly overtrimmed at the bottom panels ... and only the mid panel section 'working'.
The HoytBoom (or equivalent) prevents all this 'impossible to control, poor sail shape' ... and no matter what angle (of attack) a stays'l is flown.
FWIW (trivia) - the 'stay' immediately 'in front' of a mast is called the forestay, even if its 'temporary' ... and the use of a (even temporary) forestay 'demotes' the stay in front of this configuration to then be called a 'headstay'.
A staysail is flown on the forestay; hence its 'unshortened' name: FOREstay-sail or stays'l.
