Old 11-01-2010
Incantation is on a distinguished road
carb question for yamaha outboard
Can someone tell me what this assembly is? It sits on top of my carb on my Yamaha T9.9ELHP and when the motor warms up the pin moves down and the motor chokes.. if I pull it up i'm able to raise the rpm to a stable level and the motor functions normally. I opened it up and the assembly looks fine but I'm no expert and it's clearly not functioning properly; any advice would be appreciated. I'm sure if I take it to the dealer they will tell me I need an entire new assembly $$$
The first image is with the housing on
Thanks,
Inc
Old 11-01-2010
racer565 is on a distinguished road
does the engine rev if you spray carb quik start around it ...bad gasket....it's the elec fuel primer.....ud
yamaha outboard question with video. t9.9elhp motor Incantation Gear & Maintenance 5 10-27-2010 01:06 PM
Yamaha T9.9 question UnlikelyVoyager Gear & Maintenance 4 09-06-2010 02:51 PM
Yamaha Outboard Parts? Iflyka200s Gear & Maintenance 0 05-09-2008 10:36 PM
Storing Portable Yamaha Outboard Patrick1945 Gear & Maintenance 2 10-04-2006 11:01 PM
Yamaha Outboard? rhbroehl Gear & Maintenance 3 12-13-2001 02:16 PM
