Help removing teak toe rail - Page 2 - SailNet Community
post #11 of 11 Old 11-01-2010
I am not sure what kind of boat you have but I'll bet on the other end of that machine screw is a nut and washer. Was the toe rail raised up during the hit? If so, it might be possible the nuts and washers are up inside the space between the deck and underside. Consider looking at the underside of a section of toe rail that was not damaged.
ambianceack is offline
removing cap rail and sealing deck-hull joint tflak Gear & Maintenance 3 05-09-2010 01:44 PM
Removing rub rail jaschrumpf Gear & Maintenance 5 01-21-2010 05:57 PM
repairing teak rub rail LookingForCruiser General Discussion (sailing related) 3 04-01-2009 04:20 PM
Removing Hunter rub rail tallgeoff Gear & Maintenance 1 06-02-2008 05:33 AM
teak rub rail adamlaw Gear & Maintenance 2 12-30-2007 10:32 PM
