Winter Storage Cover - Page 2 - SailNet Community
post #11 of 24 Old 11-03-2010
Broad Reachin'
kwaltersmi's Avatar
I've been having mine shrink wrapped by the yard and have been happy so far. I use the boom and spinnaker pole from the mast to the bow pulpit as my framing. I'm surprised you've been quoted $630 for wrapping a 30 footer. My yard (not nearly the cheapest around) charges me $300 for my 28 footer. They don't include vents, by get them from Dr. Shrink.com for $1.80 a piece and put them on myself. Must be East Coast prices are much higher...
Ideally I'd use a custom winter cover, but so far I haven't wanted to fork over the cash to have one made, even though I know they're actually cheaper in the long run.
Catalina 34
kwaltersmi is online now
post #12 of 24 Old 11-03-2010
A New Adventurer
funjohnson's Avatar
We just put our cover on for the first time. It was made by a loft in CT and doesn't even go to the rails. It came with the boat when we bought it and based on the location of mast, winch pads, topping lift and backstay, it's a fit, but it seems strange to not go the extra 6 inches to the rail. Any good reason why it would have been made this way?
Here is a pic:
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #13 of 24 Old 11-04-2010
Broad Reachin'
kwaltersmi's Avatar
I cover mine primarily to keep snow and ice off of the deck, which anything that extends beyond the toerail/deck joint should do. Secondarily, I cover it to protect the exterior wood and topsides from unnecessary UV exposure. Ventilation is important, however, because a cover can make the boat become a sauna, even during winter. The high temps and humidity can cause mold problems and wood expansion/contraction.
Your cover provides good UV protection and ventilation but I'd worry about snow and ice reaching the deck and hardware, particularly with the winds and snow that come off Lake Michigan in the winter. Maybe you could have the yard add an extension so goes past your deck joint? It looks like you've got a teak toerail, which might benefit from extra coverage too.
Catalina 34
post #14 of 24 Old 11-04-2010
Check out Sea Canvas.
I've seen Carl spend a lot of time getting precise measurements.
My Canvas Store cover had to be sent back for recutting. as have several covers I know of.
Sea Canvas
Ronbo
ronbo1 is offline
post #15 of 24 Old 11-04-2010
JimsCAL's Avatar
The boom tent covers like yours are commonly sold with or without the toerail flaps. Flaps cost extra of course. The usual recommendation is get flaps if you have teak toerails, and you can skip them if you have an aluminum toerail.
JimsCAL is offline
post #16 of 24 Old 11-04-2010
A New Adventurer
funjohnson's Avatar
Fortunately, this is the only year that we are going to use the cover (we are heading south soon) and I'm not going to worry much about one year. Just more curious why they would make it like this. The only fear I have is the drain for the deck cracking and filling the boat with water. We will just go out there a few times a month to check on everything.
Thanks,
Matt
mjsailing.com
post #17 of 24 Old 11-04-2010
For a lower-cost solution, and if you have some basic drafting skills, we recommend Toledo Tarp in Ohio. (Check out toledotarp.com.) Yes, it's far from you, but they ship anywhere. Their main business is canvas covers for 18-wheelers. You do have to design your canvas yourself, but their customer service is awesome, and for $900 they could make a cover for a boat your size that would cover you down to your waterline, and last 15 years or more. The canvas is breathable but extremely (extremely) durable. Wherever you buy, I recommend getting your cover made in even three pieces, so that you don't have to deal with excessively heavy bundles of canvas when it comes time to wrap your baby for the winter.
MrsDergon is offline
post #18 of 24 Old 11-04-2010
My boat is on the hard with the mast down and has been under cover for two years now, going on three. So the cover has seen two full summers as well. I used PVC pipe for the frame and simply heated and bent it over the top of hte mast and fastened it to the lifelines. I bought two of the heaviest black and silver poly tarps from McMaster Carr. They'll make a special size if you want. However rectangular tarps don't cover tapered hulls very well. So I used a smaller tarp for the bow and simply lapped them over near the middle about 3 feet. The tarps cost me about $150 for my 26 footer. They'll make it through this winter with no problem, and probably another.
Gary H. Lucas
GaryHLucas is offline
post #19 of 24 Old 11-04-2010
WinterRiver's Avatar
Another option is to do your own shrinkwrap. It's not too hard. The first year I did it alone, which was a bit much, but I managed. The following spring I removed it carefully in two pieces, cut at the mast. The next fall I reused the shrinkwrap, adding a small new section by the mast. This season I'll use the bow section for a third time, but the larger section aft of the mast will be new.
Cost: about $250 for the shrinkwrap and tape, enough for at least 3 winters on a 47' boat.
I do it all from the deck using a hand-held heat gun. A bit crazy yes, but with patience it works just fine. It also seems much safer to me than working from a ladder. (Of course if someone would like to share a shrinkwrap gun in RI I'd be happy to help you do your boat too. But then I couldn't shrink it from the deck.) Because our boat's hull is painted, it shouldn't be shrink wrapped. I run a line along the toerail and attach the shrinkwrap around it. Ribs are made of gray pvc? electrical conduit to give us more space to work on deck.
Hylas 47
WinterRiver is offline
post #20 of 24 Old 11-06-2010
Bought a full Fairclough cover last year. It is very impressive and I think very much worth the cost. They installed it last year, so I haven't done it myself yet, but plan on doing that in a couple of weeks. They were good to work with.
BTW, I think the frame is galvanized. There was no issue last winter with dripping that stained the deck. It's fine with Awlgrip too.
They have a lot of boat designs in their files, so it is quite possible they would not need to come and measure your boat first, so that would speed up the process.
Plumbean is offline
Winter cover discoverer37 Pacific Seacraft 19 12-16-2009 03:47 PM
Winter Cover jetdrvr393 General Discussion (sailing related) 8 11-06-2009 04:26 PM
Winter cover up marcusn Gear & Maintenance 25 10-26-2007 06:24 PM
water storage vs. land storage during winter apkaplan General Discussion (sailing related) 1 10-24-2007 04:50 PM
WINTER COVER? greatwhiteway Gear & Maintenance 16 11-18-2002 03:45 AM
