11-03-2010
It would help if you said what kind of boat you have. The two holes on the mast are probably not sufficient to support the base plate of a boom vang on anything but a very small boat. The loads are proportional to the size of the boat, and without knowing what boat you have, not much can be said.
As for how far along the boom the vang should be attached, that really depends on how heavy a spar you have. The heavier the spar, the further forward a boom vang can attach. The vang should be 45-60˚ from vertical or so. Any more than 60˚ and it won't be very effective, anything less than 45˚ requires more leverage than you'll likely want to use.
