Old 11-03-2010
Tazsprout is on a distinguished road
Fixing sliding companionway hatch
First, please forgive lack of proper terminology. I just bought a boat after 30 boat-less years, and I spend a lot of time thinking.. "that thing has a name, doesn't it.....?"
Also should have read that long funny post about why you shouldn't buy the bargain boat/fixer upper BEFORE acquiring this one.
So. The companion way sliding hatch is held in place by a stip of wood with a groove in it (the flange on the hatch is retained by this groove as it slides..). On one side, the upper portion of the wood has broken off about half its length. Hatch slides OK, leaks a little, looks awful.
I have seen replacements for these intended for larger boats, in the Catalina store. I should note that mine is a 17 Holder, so the Catalina 22 is a "larger" boat.
Will I be able to modify this? Anyone have any other ideas? I am also concerned because this strip (name, please!) is slightly curved and the ones I've found on line are straight.
Old 11-03-2010
deniseO30's Avatar
Lies about her age
They should be pretty easy to reproduce in teak, mahogany or white oak.
Old 11-03-2010
You could also make the piece out of STARBOARD or UHMWPE. Photos would help...Recommend you read the POST in my sig to get the most out of sailnet.
Old 11-03-2010
stumartell is on a distinguished road
I would recomend going to catalina Direct. They specialize in Cat 22 and 25
Old 11-03-2010
Might want to read the OP again. He doesn't have a Catalina, he has a HOLDER 17.
Old 11-03-2010
CaptainForce's Avatar
I don't have the same size vessel, but I did place a strip of polycarbonate under the slide and bordered it with black starboard plastic.
The polycarbonate strip makes for a smooth and quiet slide. Take care and joy, Aythya crew
Sliding hatch removal? jaschrumpf Gear & Maintenance 2 05-15-2010 09:51 PM
Catalina 22 sliding hatch boards??? ABLiveSurfdotcom Gear & Maintenance 7 04-21-2010 09:22 PM
sliding hatch QuickMick Gear & Maintenance 2 02-17-2010 11:16 AM
Sliding hatch question. C27Shockwave Gear & Maintenance 3 12-21-2006 08:17 PM
Hard to Open Sliding Hatch sjacovino Gear & Maintenance 6 02-13-2002 07:29 PM
