Running all lines to cockpit - Page 2 - SailNet Community
post #11 of 15 Old 11-04-2010 Thread Starter
Originally Posted by BigZ View Post
Not familiar with the S2 you have, but it sounds like you have a hinged maststep which allows for easy raising and lowering the mast. If so, you could put the plate mentioned earlier beneath the existing plate on the deck. Just have to lower the mast, pull the pin to release the plates, unscrew the plate from the deck, copy and drill the hole pattern to the new plate, remount the new plate and old deck plate, then raise the mast.
The mast plate is probably the best way to approach your problem. But standup blocks with proper backing plates would probably also work ok on a boat this size. It's just more holes in the deck.
Yes, thats exactly what I have. There are 4 large bolts in the plate. I know this will sound like a stupid question but can I take them out? What are they threaded into? I don't want to pull them out then be in for a surprise with what I find underneath.
jetdrvr393 is offline
post #12 of 15 Old 11-04-2010
Should be no problem taking them out. Try one and see what happens. I think it would withdraw pretty easily. The worst that could happen is you find damp wood on the threads. If that happens, well, that's a new thread.
Not sure what S2 used to do when they built these boats, but they have a pretty good rep on most of their boats. The screws are probably coarse thread wood-type screws and are most likely screwed into a solid fiberglass mass. The screws just keep the plate from moving fore/aft, there's not too much strain on them really. If you pull them all, just re-bed the plates to keep water from seeping into the holes.
BigZ is offline
post #13 of 15 Old 11-05-2010 Thread Starter
I'm not sure I want to go down this road. The boat is a 1979 and I know that S2's have a reputation for being well built but I'm not convinced that the reward outweighs the risk of something bad happening when I would pull the plate. We sailed the boat all summer without the lines run the way I want and did just fine. I am planning on upgrading to a bigger boat within 2 years and would hate to have a major issue over this.
Are there any other options other than the mast plate?
post #14 of 15 Old 11-05-2010
I think it's a very low risk option, and mounting standup blocks is adding more holes. But there is another way that might work.
Before I purchased and installed my mast plate I wanted to arrange the organizers and clutches, etc., so I tied a loop of 3/8 sta set with several blocks on it around the mast base just so I could lay things out. Then I kept forgetting to buy a mast plate over the winters and ended up using this loop for several years. It worked fine for lines like cunningham, outhaul, and vang, never riding up the mast or chafing. I didn't use it for halyards though, so not sure if it'd work in that case, but it might be worth a shot. It wasn't a real pretty installation, but it was cheap and did work until I finally bought the plate.
BigZ is offline
post #15 of 15 Old 11-08-2010 Thread Starter
It probably is a low risk option, I'm just kinda scared to pull the plate.
I like your idea of the loop, I could probably do something like that, my halyards are in the mast so I would only need it for reef lines, cunningham, vang and outhaul.
Tidying Up Lines in Cockpit bacampbe Seamanship & Navigation 11 06-23-2010 04:53 PM
Moving control lines to the cockpit? Garffin Seamanship & Navigation 9 11-29-2009 04:58 PM
running all deck lines diverdad69 Gear & Maintenance 2 06-07-2009 08:26 PM
Islander 32 Running lines to the back thisisus Gear & Maintenance 2 02-28-2009 11:11 AM
Running lines aft Columbia 26? Mandofish General Discussion (sailing related) 0 12-03-2008 07:50 PM
