Joker Valve? - Page 2 - SailNet Community
post #11 of 14 Old 11-05-2010
Best Looking MALE Mod
Cruisingdad's Avatar
WS - Pleaes tell us how it turned out when appropriate.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #12 of 14 Old 11-06-2010 Thread Starter
Thanks guys. I'll update you when (if) I solve the problem. This site has been enormously helpful to me in bringing my head into the 21st century.
Answering some suggestions: I have a vented loop on the overboard discharge, which diverts off the tank line with a y-valve (handle removed). The tank inflow does not have a loop as it does not go overboard and cannot siphon seawater into the boat. This backflow occurred while testing the overboard discharge with seawater only. It happened slowly, I didn't notice the extra water in the bowl until later. After that I pumped some air through the line by operating the pump. That seemed to solve it. I don't know if the valve cleared or the water was just all overboard.
WanderingStar is offline
post #13 of 14 Old 11-06-2010
Old as Dirt!
svHyLyte's Avatar
WStar---
One arrow you might want to add to your quiver for head meintenance/longevity that I have found very helpful is to keep a squeeze bottle (used liquid soap bottle or whatever) with a mix of SaltAway and water in the heads. We have and when anyone uses the head, once they've pumped the bowl empty and flushed the system (at least 5 added pump strokes please) we ask them to put a good squirt of the SaltAway mix in the bowl and give the pump a few more strokes. Getting this material into the waste lines prevents the built-up of salt and calcium carbonate in the lines and seems to help preserve the flapper valve and joker valve and our heads remain clean and functional. I do a maintenance call on the units (we have two) annually but can easily get two or three years on a set a valves (more if I wanted to push the issue). While SaltAway is not inexpensive, one needs only 1+/- oz in a large (34 oz) squeeze bottle so it is a cost effective way to help maintain the head equipment.
FWIW...
svHyLyte is offline
post #14 of 14 Old 11-07-2010 Thread Starter
Thanks. The old lines were full of coarse deposits.
Fuel Valve HorizonHunter Gear & Maintenance 8 02-05-2010 05:39 PM
Engine won't run. Solinoid Valve? Gummy Gear & Maintenance 19 10-25-2007 08:28 PM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
Diverter Valve drynoc Gear & Maintenance 1 11-17-2005 01:08 PM
GATE VALVE drynoc Gear & Maintenance 2 03-08-2004 05:16 AM
