Old 11-07-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Lady J week 14, I think....
Just a quick update. We've started scarphing in mast sections prior to assembly. Here we are matching the curves.
Now we're checking the joint lines.
A ton of work to get dissimilar pieces to match up before we make the round-over cut. We have three spray coats on her since the first blocking now and she's starting to shine. Only two more to go before the final blocking to remove any grain dips and level the surface and then two to three more spray coats.
Here's a couple showing the sides of the hull without flash.
Portside forward
Portside aft
Starboard forward
Starboard aft
Two photos of the same spot aft both with and without flash.
and
A little reflection test on the aft toe/transom rail.
These may be the least shots from this old building since we are moving to a newer, larger building this next week.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 11-07-2010
Ob-la-di, Ob-la-da :)
Sixpoint is on a distinguished road
This is easily my favorite series of posts on this site. Amazing work, man.
Old 11-07-2010
On the hard
Thanks. Nice to see new posters in my threads.
Bellingham, WA.
Old 11-07-2010
Sabreman's Avatar
Sabreman will become famous soon enough
Charlie -
I have a question regarding the spraying of finish vs. hand application. I know that it's difficult to keep a wet edge when hand applying finish, especially in warm weather. Given your location, I would think that's not an issue. Do you spray because it reduces (but not eliminates) the potential for drips and sags? I know that it's much faster to spray so that may be a consideration too?
The finish is looking really great and it will be amazing to see the final product. I'm learning some nice details watching the progress; I wish that I was there to see the progression live. Keep up the great work.
Sabre 38 "Victoria"
Old 11-07-2010
On the hard
I used the brush application for high build purposes. Even with Penetrol, you still have some minute brush marks in varnish. Not so with spraying.
Bellingham, WA.
Old 11-07-2010
Sabreman's Avatar
Got it. I've had the same experience even using Penetrol. Love that stuff and use it in my furniture building from time to time. Most of my finishes are hand applied because of the small area. Depending on the circumstance, I may final sand at 220 and then apply a final coat, rubbing out with rottenstone, and then applying a final coat of furniture wax.
Looking forward to your next installment.
Sabre 38 "Victoria"
Old 11-07-2010
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
Beautiful work Charlie. Good luck on the move to the newer bigger building.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
Old 11-07-2010
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
Bad ass as always!
Charlie, PLEASE! get some distance shots of her when she's moved to the new building!!! I would love to see her from a far, shining in the sun!!!
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Old 11-07-2010
On the hard
It's November in the PNW...., WHAT sun??
Bellingham, WA.
Old 11-07-2010
I'm not picky! I'll take some overcast/rain shot then!
S/V Frida
The restoration of Lady J, week two. CharlieCobra Gear & Maintenance 11 11-09-2010 12:42 PM
Lady J, week 13. Did somebody say varnish? CharlieCobra Gear & Maintenance 11 10-22-2010 08:04 PM
Lady J, week 10.5, almost too busy to get up here... CharlieCobra Gear & Maintenance 15 10-08-2010 10:23 PM
Lady J, week three, a long one... CharlieCobra Gear & Maintenance 7 08-13-2010 09:00 PM
Lady J, week one CharlieCobra Gear & Maintenance 14 07-31-2010 08:19 PM
