Old 11-09-2010
csommers79 is on a distinguished road
Waterproof Temporary Putty Sealant
Hi -
I need to replace a seawater intake hose barb on my stern tube (which has a cutlass bearing on the prop end and a prop shaft seal on the end near the transmission). To do so, I plan to disconnect the shaft from the transmission and slide the shaft out so the intake hole on the stern tube is clear of the shaft. However, water leaks in to the boat through the cutlass bearing where the shaft protrudes from the skeg - I have been told there is a waterproof putty I can wrap around the shaft and cutlass bearing, that won't bond or set up, to temporarily keep water from flowing in - is anyone familiar with such a product? West Marine doesn't seem to know, nor does Lowes or Home Depot... Please email me at csommers79@gmail.com with any thoughts or suggestions! I just need a temporary patch of sorts to allow me to dry out the inside of the stern tube while I'm working on it...
Old 11-09-2010
QuickMick's Avatar
QuickMick is on a distinguished road
this might work...
Amazon.com: 3/4" X 30' Butyl Tape: Home Improvement: Reviews, Prices & more
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 11-09-2010
okawbow is on a distinguished road
butyl tape
You can get butyl tape at an RV store.
Chuck
Bristol 24 on Midwest lakes, rivers, to the Gulf
Old 11-09-2010
erps's Avatar
the pointy end is the bow
You can also buy it by the brick at Home Depot for $1.60 a pound.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 11-10-2010
ottos's Avatar
Señor Member
ottos is on a distinguished road
Sounds like plumber's putty to me. It's used between the sink and the counter, or the faucet and sink. Never sets.
Old 11-10-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
A toilet bowl wax ring would also work. Around $2 for 1 ring at HD or hardware store.
Old 11-10-2010
RichH's Avatar
RichH will become famous soon enough
Plumbers Putty !!!!
How to waterproof Sunbrella?? BlowinSouth General Discussion (sailing related) 15 06-25-2008 05:32 PM
Ok, they're clean now so what do I waterproof them with? CharlieCobra Gear & Maintenance 13 11-22-2007 12:58 PM
Grey Marine-Tex Putty on fiberglass? Jonathan316 Gear & Maintenance 1 05-28-2005 05:51 PM
temporary jib set-up sailorman_10 Gear & Maintenance 3 03-29-2002 03:34 AM
WATERPROOF FLASHLIGHTS SHIMSHON Gear & Maintenance 6 06-07-2001 05:59 AM
