Old 05-13-2003
namaste04 is on a distinguished road
Rudder replacement/repair
Argh! A big setback in our refit! Neil dropped the rudder last night and found corrosion on the 2" SS stock. We need to get a new stock made (that sounds VERY expensive) and build a new rudder around it. Anyone done this? Any advice? The boat is a 1981 Mariner 39 (built in New Hampshire.) The rudder is fiberglass.
Thanks
Stacey & Neil
http://www.sailnamaste.com
Old 05-13-2003
miahmouse is on a distinguished road
a little bit of corrosion doesn''t mean the end for the rudder (I''m not there to judge but if it''s just on the surface, sand it off polish it up and keep on rolling). If it has definitely had it, then it''s time to start searching for a reputable machine shop. Then there''s choosing the metal. 302/304 Stainless will be slightly more flexible/less prone to cracking but more prone to rusting. 316 Stainless will be less prone to rusting but is more rigid and therefore prone to breaking/cracking. 316 will also be more expensive. Next up will be the design/copy of the old rudder. Being that you haven''t sailed the boat I''d try and contact another owner of a Mariner 39 and see what they have to say. Figure out what materials you want to use for the core, skin and most importantly, resin. If you have access to a vacuum pump, you might consider vacuum bagging to increase rigidity. I''ve never build a rudder for a boat over 20ft so I can''t give much advice on design matters dealing with the loads of a larger boat. But I will say this, do it once and do it right.
Old 05-13-2003
JDAM is on a distinguished road
Not so easy to correctly build a new rudder, at least my .02 . Check with Foss Foam @
http://www.newrudders.com
Old 05-13-2003
I need to epoxy over a new teak veneer cabin sole. Are there any products anyone on the board has used for this job which worked well or others that should be avoided.
Thanks in advance
Old 05-28-2003
talessi is on a distinguished road
In need of the coller that secures rudder post and tiller. I have a 27''Newport. Any suggestions?
Building a New Ruuder Armchairprotest Gear & Maintenance 16 12-06-2009 10:15 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Rudder repair, blister & more Burnsy Gear & Maintenance 0 03-07-2004 06:46 PM
Tayana 37 Rudder Assembly srubin General Discussion (sailing related) 0 12-03-2001 07:11 AM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 03:30 PM
