11-15-2010
islander bahama 24
first i have to say i have no experience with beneteau's however if they do have nylon friction washers like mine on my islander the washers are available at just about any good hardware store lots cheaper than at a marine store. all you need is the size of bolt it goes on and the outside diameter of the metal washers it jams with. unscrew the bolt and install the nylon washer. (also available at most auto parts stores) called fiber washers. let me know if this helps rob
Illegitimus Non Tatum Carborundum.
