Old 11-15-2010
westerly33 is on a distinguished road
Mainsheet traveler on small ketch
Hello,
I am wandering whether mainsheet traveler installation on small ketch makes sense? I think that keeping the main to close will backwind the mizzen and that is why it is useless.
There is no traveler on my boat and as I can see some bigger ketches have no mainsheet travelers as well.
Regards.
Old 11-15-2010
WanderingStar is on a distinguished road
My ketch has no travelers either.
Old 11-15-2010
Allanbc's Avatar
Allanbc is on a distinguished road
My ketch doesn't have a main traveler either. I agree that the main would probably backwind the mizzen.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 11-15-2010
Jeff_H's Avatar
Super Moderator
Adding a traveler would allow you to adjust twist in the mainsail and adjust the angle of attack, so that you would be able to minimize the negative impact of the downdraft (backwind) from the mainsail on the mizzen while also controlling the impact of backwinding from the jib on the mainsail. In many ways the interaction of the mainsail and mizzen on a ketch means that a ketch needs a traveler a whole lot more than a sloop or catboat.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 11-15-2010
klem is on a distinguished road
I have a traveler on my ketch and it is incredibly helpful in controller sail twist as Jeff suggests. The boat really would not sail as well without it. A boom vang would allow some of the same control but a traveler would be best.
Old 11-16-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
I have a traveler on mine.marc
Old 11-16-2010
Jeff, how long is your traveler rail?
I can install only 26 inch rail. Do you think it worth it?
Thank you.
Alexei
Old 11-17-2010
christyleigh's Avatar
christyleigh is on a distinguished road
Mine is about 48 inches from the factory but anything you can do to add more adjustment possibilities is a Good Thing..... never bad. I also added a crude but functional knotted rope traveler to my mizzen that came with none since the very beefy dingy davits provided the attachment points. I have to manually move the mizzen mainsheet connection from knot to knot for adjustment but the forces on the mizzen on my small boat are so small it's easy to do.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 11-17-2010
Jeff_H's Avatar
Super Moderator
Thank you.
Alexei
I actually own a performance oriented sloop with nearly end boom sheeting so my traveler is around 6 feet long, but the small ketches that I sailed had roughly a 3 to 4 foot long track.
mainsheet traveler sailstein General Discussion (sailing related) 0 04-08-2010 03:16 PM
CS34 New Mainsheet Traveler padean CS Yachts 0 02-08-2009 09:57 PM
Mainsheet traveler opinions? Izzy1414 Gear & Maintenance 7 01-24-2009 10:30 PM
Wanted S2 9.2A Mainsheet traveler info SantaSailor S2 3 05-07-2008 03:38 PM
Mainsheet traveler buddabelly Gear & Maintenance 14 11-04-2007 08:28 AM
