Old 11-15-2010
dvpamenter is on a distinguished road
antifouling for prop and shaft
Hauled Ossifrage 3 weeks ago. Hull was very clean, but prop and shaft were heavily coated with crustaceans. Boat is in Atlantic Canada waters. Any one with any suggestions for anti-fouling metals?
Don
Clear Sailing
Alado agent - Canada
Old 11-15-2010
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
If your boat is seldom used than lanocoat on the prop will shed growth, but will not stand up to a lot of motoring.
Old 11-15-2010
October Moon B43
MJBrown is on a distinguished road
I used plain lanolin on my prop this past spring. While the boat wont be hauled for another couple of weeks I had a diver clean the bottom in early fall and he noted that the prop blades were barnacle free, but the hub/shaft were coated with them. Next spring I'll make sure I add more to those areas that didn't hold up as well and see if I can keep the prop clean. A cheap fix and worth the try.
Old 11-15-2010
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
out drive anti fouling paint, it comes in "clear" also.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 11-15-2010
jrd22's Avatar
Courtney the Dancer
Trilux antifoul spray for outdrives. West M has it, about $20/can. Works great here in the PNW, two years and no hard growth. Clean till shiny with Scotchbrite then prime with zinc chromate spray, then two coats of the antifoul.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-16-2010
ASA and PSIA Instructor
Pettit zinc coat barnacle barrier spray paint has always worked well for me.
Old 11-16-2010
Thanks all. Recently found a product called Prop-shield which is lanolin based. Likely just lanolin at a few more $$.
Clear Sailing
Old 11-17-2010
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Me too! In Seal Harbor, Maine, Pettit's zinc spray works very well. Just surface slime after 6 months. It is cheap, simple to apply and it really works. I apply three coats.
Down
Old 11-17-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Down
Me too, although I haven't checked on it since the water got cold.
Regards,
Brad
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
Antifouling and Zincing a Kiwi Prop alex909 Gear & Maintenance 5 04-01-2010 01:52 PM
Antifouling Prop & Shaft Foolishness323 Gear & Maintenance 9 12-07-2009 09:24 AM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Antifouling for prop and shaft? sail268 Gear & Maintenance 17 12-04-2006 07:06 PM
