11-16-2010
Psst, you can't directly magnaflux Stainless unless it has a high Iron content <306 (cheap stuff) since it isn't magnetic.... If it's 316, 318+ grade like most boat/marine stuff, magnaflux is useless since the chromium and or Nickle content is too much.
Magnaflux works by finding another N/S magnetic pole (a crack) across a "magnetic" piece and the powder finds both sides of that crack or if there's no fracture, a solid/even powder dusting across the piece like you dropped whiskers from an electric shaver on a piece of paper.
You can also put a piece of stainless strip/plate etc. on a special steel plate w/ a mag unit under it, then you can mag that then drop the iron powder on top of that to see how it looks. Not as good as the next part;
FWIW, "Zyglo" testing (or other dye/blacklight methods) works best w/ any non-ferrite stainless, copper, brass etc..
You can buy Zyglo and a blacklight and check everything you want for cracks, it's a simple procedure
HTH!
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Reason: spelling
