outboard motor on o'day 27' - transom strength? - Page 2 - SailNet Community
post #11 of 12 Old 11-18-2010
imagine2frolic's Avatar
I really like the idea of using thinner ply, and adding to it if the stern is not flat, and the larger the better.........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #12 of 12 Old 11-18-2010
whatever you do, spread the load over as large an area as possible. Don't forget to encapsulate the plywood in fiberglass, or at least epoxy saturate it. Also, don't forget to pot the holes going through it.
sailingdog is offline
Outboard Mount and the transom of a Cal 20 lostcoast Cal 9 03-04-2013 12:26 PM
transom outboard backing board tmalcolm Gear & Maintenance 11 06-17-2010 01:19 PM
Workable motor for Dink w/20" transom? GKinTN Gear & Maintenance 0 07-07-2009 03:16 AM
Reinforcing transom for motor mount and ladder. zz4gta Gear & Maintenance 1 06-11-2008 06:24 PM
outboard fuel pump strength wgwl13736 Gear & Maintenance 5 08-16-2004 08:03 AM
