Boom - SailNet Community
post #1 of 3 Old 05-13-2003 Thread Starter
Boom
Three years ago I was washing the salt off my main in a light breeze. Suddendly the wind gusted to over 40 MPH. My boom broke in the center right where my main sheets connect. I had it welded but it isn''t holding it''s shape....It''s time to replace it. It''s on a 29 foot Lancer it''s 10'' long. I know if I could find one about the same size that I could make it work with my mast. Anyone know where I could find a nice used boom?
jbanta is offline
post #2 of 3 Old 05-13-2003
Moderator
Jeff_H's Avatar
Boom
Unless your boom used welded fittings you should be able to buy a new spar section from Dwyer or Kenyon pretty inexpensively and then use your old fittings to build a new boom. It is unlikely that you will find a used boom that will fit your boat but who knows?
Good luck,
Jeff_H is online now
post #3 of 3 Old 05-14-2003
Boom
I''ll second that opinion. Don''t expect to be able to use the old end caps, and you''ll be lucky if you can re-use your gooseneck. Look at some sections at www.dwyermast.com. There''s lots of other options out there, but they seem to go up in price significantly. Hall spars and rigging (http://www.hallspars.com) and charleston spars are also well worth a look but will be a good deal more expensive.
miahmouse is offline
Boom Kicker Boom Vang dwottavian Gear & Maintenance 5 01-11-2010 12:48 PM
Sail covers for loonnnggg mizzen boom kbennett17 Gear & Maintenance 1 08-06-2002 12:49 PM
Boom Brake KIKO Gear & Maintenance 0 03-17-2002 03:39 PM
In the boom furler TomAbbottJr Gear & Maintenance 0 10-27-2001 12:52 PM
Boom brakes on cruising catamarans steven.warren Gear & Maintenance 1 11-29-2000 05:03 PM
