solar powered vent - Page 2 - SailNet Community
post #11 of 16 Old 11-19-2010
ancient mariner
captbillc's Avatar
i have a plastic solar vent that came with the boat. i like the fact that the fan is always going to keep humidity out . it is on the cabin top. i have to keep a 5 gallon pail on the table under it when i leave the boat because when it rains some water will leak in.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
captbillc is offline
post #12 of 16 Old 11-19-2010
MARC2012's Avatar
Gee mine generally leaks when it rains.When sunny & calm no problem at all. marc
MARC2012 is offline
post #13 of 16 Old 11-19-2010
I've got two Nicro solar vents, the older more expensive model that came with a bronze deck ring, and they don't leak at all. Been running for close to FIVE years now too.
sailingdog is offline
post #14 of 16 Old 11-19-2010
Underwater Basket Weaver
TintedChrome's Avatar
Does anyone have experience with these installed on hatchboards? Does the reduced exposure to sunlight from being vertical or facing away from the sun certain times of day make a big difference in their operation?
Regarding water ingress from it being vertical I was planning on installing a small hood above it..
s/v Tinou
1976 Northstar Farr 727
Hull #37
I can't imagine mastering the skills involved here without a clearer understanding of who's going to be impressed.
TintedChrome is offline
post #15 of 16 Old 11-20-2010 Thread Starter
Thanks to everyone, your all great as always and the best advice. Let you know how it turns out.
Walt352 is offline
post #16 of 16 Old 11-20-2010
dhays's Avatar
Originally Posted by bluwateronly View Post
I am not understanding why someone would put a 4" hole in a deck. Dorads okay, if you can plug in heavy weather. The problem I see is if you go upside down that's alot of water that can get in. I won't even mention core problems if not installed correctly. All this for a little air that a porthole provides when needed. I would glass it and fair it then gelcoat it. Just me.
Based on your username, I'm assuming that you spend a lot of time in open water. However, many of the rest of us don't, and adequate ventilation with deck top vents isn't a problem.
Dave
47⁰20'11.7" N
122⁰35'20.8" W
M/V Kinship, North Pacific 43
Formerly
S/V Legacy, Catalina 400 MkII, Hull #328
dhays is offline
Nicro Day-Night 2000 solar vent repair Groven Gear & Maintenance 100 1 Week Ago 08:59 AM
Solar Vent Fan - Where to Put It? montenido Gear & Maintenance 14 10-08-2010 11:23 AM
older Nicro solar vent mounting question argofred Gear & Maintenance 6 07-08-2010 07:11 AM
Solar/Air Vent Effectiveness kwaltersmi Gear & Maintenance 29 04-01-2009 11:37 AM
Solar Micro Vent Location dtallman Gear & Maintenance 8 02-18-2008 03:40 PM
