1. We still have more weatherhelm that I'd like in 15kts. Mast tuning options are minimal, but I understand that a flatter main will help alleviate the problem.
**** so also will having the having a sailmaker come to your boat and see if the POINT OF MAXIMUM draft is correct. .... if its an old sail most probably the boltrope rope (if it has one) has drastically 'shrunken' --> draft aft, 'baggy', too tight + 'hooking-to-weather' leech etc. which yields 'slow boat', cranky boat, boat that aggressively heels, etc. ..... and most possibly youre not giving proper main halyard tension to correctly set where the point of maxium draft should be on the 'old' sail. Next time out and as a trial, when on a hard beat and you perceive 'weather helm' ... crank on tension on the main halyard until your 'weather helm' disappears. A boat your size needs the main halyard (sail luff) , additionally stretched out by an 'additional' 4- 4.5 inches to get to the 'as designed' shape of the 'dacron' sail !!!! .... in sailmaker-speak is called '"removing the boltrope 'preload'". I claim that most 'weather helm' problems (on boats with boltroped dacron mainsails) is because the Msail isnt 'raised' sufficiently, ... not enough tension on the HALYARD.
Here's a link to a posting I did on another forum about *HOW to properly raise a dacron mainsail*:
How to properly RAISE a woven dacron mainsail - SailboatOwners.com
2. We do 1-2 races a year, but I'd like better performance overall. Cross-cut or tri-radial? I'd like to stay away from laminates but NorDac Radian looks like an alternative for a dacron tri-radial. Opinion?
*** for only 1-2 races/yr. and for shape 'versatility' cross cut with 'high quality' cloth will get you there.
3. My current main, the original, is nearly roachless. I'd like to max the roach without interfering with the backstay. Opinions?
*** again, get a sailmaker ON the boat to 'measure' the max. distances .... unless you can give the exact amount/dimensions/degrees of current 'mast rake'. A roach that is overlapping the backstay by a slight amount isnt going to be a problem ... but get 'chafe protection' added if you and your sailmaker agree to such an 'overlap'.
4. The PO had the existing main retrofitted with full battens to increase longevity. Should our new sail have a) 4 full battens, b) 2 full, 2 partial, or c) other combination?
*** 2 full + 2 'long' battens are the most versatile (especially when reefing) .... 'tapered battens', and suitably reinforced batten pocket ends, that is.
5. Loose or shelf foot?
*** Loose footed, for more 'adjustability' .... you wanted 'flat' that's the best way to do it.
6. Anything else that I forgot to consider?[/QUOTE]
*** over-the-top leech line. Permits leech control from the safety of the mast base, so you dont need to hang out over the water 'futzing' with a leech line when the boom is 'way out'. also the leech line cleats (at each reef point position) so arranged that pulling from a lower position automatically 'releases' the cleat at the 'next above' position.
7. If new sail is 'boltroped', precise measurement of the Tack to head (luff) connection distance (**for your 'records'**).... so you know 'when' and 'how far' to have the boltrope 'eased/adjusted' in the future.
8. If sail is boltroped on luff, have the sailmaker add extra length of boltrope at the head (secured to the headboard, etc.) so that any future boltrope 'easing' is cheap and fast. Without the 'stored and ready-to-go' extra boltrope length such 'easings/adjustments' can be time consuming and expensive. Plan on DIY readjusting the boltrope length after every season --- all you need is a tape measure, waxed heavy sail-twine and sailmakers needle-palm + triangular sailmakers needle. (If your 'old' sail had this 'feature' you'd probably be 'easing/adjusting the boltrope' instead of buying new.)
hope this helps.
