11-19-2010
Yes, it only slides about 1/8-1/4" or so. It is designed to allow you to tip the can upside down without gasoline pouring out... it isn't meant to be stored with that spout in place—you're supposed to store the jerry can with the spout inverted.
Originally Posted by rmeador
I just bought two of these jerry cans. I can't figure out how they're supposed to be used, and they didn't come with a manual. I've been able to figure out from searching online that the wide part of the spout is supposed to slide when the nozzle is pushed down into the fuel tank, and that opens the valve, but the ones on my jerry cans don't move much (maybe 1/8"). Is that all the throw there is? That doesn't seem sufficient, and if it is, it means they'll be very likely to randomly open on their own, so I need some better way of sealing them for transport. Are they supposed to be stored with the spout turned around (inside the can), and you only pull it out into the normal orientation to pour it? That seems like it would make for a very messy spout and would negate the supposed zero-spill benefit of this design. What am I missing here?
