Old 11-19-2010
montenido's Avatar
montenido is on a distinguished road
Stern Roller - Does Anybody Have One?
Hi all,
the general areas where I like to cruise seem to call for anchoring both bow and stern. Not a big deal, but it seems that installing an anchor roller on the stern would make life much easier while dropping and retrieving that anchor. As it happens, I do have a nice new roller that would fit.
Do any of you have such a setup? Comments pro or con?
Thanks, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 11-19-2010
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
I do not have one yet, but would like to add one if I find just the right one, and it is cheap. it's not a high priority at this point, but I have anchored off the stern several times, either bow and stern, or just a lunch hook off the back as it is lighter for a quick stop in clam waters. However, retrieving from the stern is harder then it should be and a stern roller would help. Not to store the anchor on, just to run the rode on for retrieval.
Not much help since i do not have one so I can only say, i like the idea too!
S/V Lilo
1964 Islander 32
Saint Helens, OR
Old 11-19-2010
We have one but mainly use it to lead the stern tie line over the transom. I think the practical usefulness of one as an anchor roller will depend on it's location and the style of transom the boat has.
1984 Fast/Nicholson 345
Old 11-19-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
We don't have one (canoe stern), but if memory serves the Pardys have one on Taleisin mounted to the underside of the boomkin.
Old 11-19-2010
jrd22's Avatar
Courtney the Dancer
We have one, it is small, used for a smaller Danforth lunch hook. Like Faster we have used it for the stern tie line, but have used it for pulling the prawn trap line mostly (500' of poly line). It makes pulling the line a lot easier because you don't have to worry about keeping it away from the hull/rubrail and can really pull on it from in the cockpit instead of hanging over the railing trying to pull it straight up (makes it a lot safer too). Ours is mounted on the port side just at the corner of the transom.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-19-2010
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 11-19-2010
PorFin's Avatar
Señor Member
Originally Posted by Craig Smith View Post
Now, why does this not surprise me?
Old 11-20-2010
lshick is on a distinguished road
Send a message via Skype™ to lshick
We have one on our canoe stern, rarely use it.
For "bow and stern," consider dropping a 2nd bow anchor (as though you were going to do a Bahamian Moor), and then walking the 2nd rode along the rail and securing it at the stern. Disassemble in the reverse order of assembly. That way you have the windlass at the bow to help with retrieval of both anchors.
Larry Shick
V42-148 "Moira"
Jackline: to stern or not to stern dreuge Gear & Maintenance 10 12-24-2009 12:23 PM
Stern docking nthompson General Discussion (sailing related) 8 08-04-2004 12:19 AM
Bow or Stern? mattyc Learning to Sail 6 05-14-2002 10:25 PM
Stern Anchors Mark Matthews Seamanship Articles 0 08-14-2000 08:00 PM
Stern Anchors Mark Matthews Cruising Articles 0 08-14-2000 08:00 PM
