11-21-2010
It would be a lot of work to make the cabin a foot longer without compromising the integrity of the cabintop and deck. Unless you're very good with fiberglass repair, it isn't likely you'll be able to do this safely. It may also have some negative unintended consequences, as making the cabintop longer increases the windage and raises the center of gravity slightly.
