Old 11-21-2010
rayjanine is on a distinguished road
Doyle Stack Pack vs Shaeffer Boom Furler
I am planning on buying a Sabre 362 and would like to know the difference between the Doyle Stack Pack System for the Mainsail vs the Shaeffer In-Boom Furler for the Mainsail. I think the in-boom furler is the preferred system but would like to know:
1. The cost of each system
2. Pros and Cons
3. For each system what installation advice would you give
4. What parts fail and how soon after installation
Thanks,
Ray
Old 11-21-2010
The Doyle Stack Pack is simply a system where the sailcover and lazyjacks are incorporated into the sail and boom so that when you drop the sail it falls into the 'cover', after which you close it up. Our friends had such a system when they bought their current boat; they've since ditched it. I believe their issues centered around ease and convenience of reefing - this was a Bene 36.7 sailing the Caribbean chain in the trades.
In-boom furling is quite a different thing.. but as a mainsail furling system has the benefit of allowing a normally roached/battened sail.
WAG on the prices, but I can't imagine that the Doyle system would add more that $500-1000 to the overall cost, whereas inboom furling will probably run you $10K or more.
Hopefully someone with more direct experience will weigh in here.
1984 Fast/Nicholson 345
Old 11-21-2010
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
In my research Faster's numbers are close, and possibly a wee bit higher for the furler if someone else installs it.........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 11-22-2010
Omatako's Avatar
Omatako will become famous soon enough
If I had in-boom furling I probably wouldn't swap it for a Stackpac.
But I have a Stackpac and I know that I won't be swapping it for a furler. 10K buys a heck of a lot of beer.
Arthur C. Clarke
Old 11-22-2010
BarryL's Avatar
BarryL is on a distinguished road
IMHO
PRO for Stack Pack:
-Can be installed on any traditional mainsail
-Relatively cheap to install
-No sail cover to remove and install
CON for StackPack
-Sail cover is always 'on' so some lose of performance under sail?
-Can be difficult to reach the top of the cover to close
PRO for in boom
-Allows full batton, full roach main
-Easy to reef
-East to stow sail - no sail cover required
CON for in boom
-big $$
-More difficult to raise main - additional drag of furliing gear
-more complexity
-additional weight
Personally, I have never used an in boom furler but the concept sounds great to me, as long as someone else pays for it.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 11-22-2010
PalmettoSailor will become famous soon enough
Originally Posted by BarryL View Post
IMHO
PRO for Stack Pack:
CON for StackPack
PRO for in boom
-Easy to reef
CON for in boom
-big $$
-more complexity
-additional weight
Barry
I pretty much agree with Barry, but want to add a couple of comments with regard to my specific solution which is the "MackPack" from Mack sails.
Their design is less expensive than the Doyle system and is independent of the sail. My understanding is the Doyle bag is sewn to the foot of the sail while the MackPack simply attaches to the boom via sail slides.
The design of the Mack Pack lazy jacks allows for them to be lowered out of the way with the bag stowed alongside the boom, so the sail would be completely unimpeded. For typical bay sailing you probably would just leave them up, but for racing or long passages, it would make sense to stow them for several reasons including eliminating chafe, minimizing any possible performance loss and simplifying access for reefing.
I installed the MackPack at the start of this season and am very happy with them. They eliminate what used to be a major wrestling match for both my wife and I and made it pretty much a one person operation. I find I'm much more willing to raise the mainsail, knowing that even if things start getting rough I can get the sail down in a hurry and stow it later if I have to.
I do agree that the top of the sail is fairly high and its a challenge for my wife to attach/detach the halyard so its usually me doing that task now.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Old 11-22-2010
tommays's Avatar
I have the Hood boom which is pretty much the same thing with full battens and have only used it once before hauling the boat for refit
All the roller booms have the same issue in that you have to use the topping lift to set the boom at 87 DEGs to furl the sail if its to low or to high it will not furl correctly
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-22-2010
jackdale's Avatar
jackdale will become famous soon enough
One other con for the Doyle Stack Pack:
The lazy jacks cannot be brought to the mast for stowing. This means that the battens may get caught in the lazy jack lines.
With the lazy jacks stowed, you can use a regular sail over.
No experience with in - boom systems.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 11-22-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
I'm learning here too. I thought I had a Doyle Stack pack, but I have a loose footed main and the stack pack is slid onto the boom. Maybe it is a Mack Pack? A front cover piece zips off and there are slits in the side for reefing lines so reefing is very easy.
The lazy jacks are easy to slacken so they don't interfere with raising the main. I never really have to bring them back to the mast. A little slack does the trick.
There are battens on either side. (I still need to cut on of them; it's a bit too long.) You can lower the whole thing so is droops down below the sail, but generally I leave it in place.
We also have a liferaft in a hard case mounted on the deck. Standing on it puts the top zipper within reach.
I'm soloing a lot these days (yesterday for 4 hours, last Sunday), and having this system makes it really easy to get underway and then to put everything away afterwards. Dropping the main takes seconds; it falls right in place.
Here's a picture of it:
A later picture with the reefing lines set-up. They go through the slits in the stack pack and are tightened from the forward end of the boom. Here the main is double reefed.
Regards,
Brad
Old 11-22-2010
rmeador is on a distinguished road
Bene505, that looks exactly like my Doyle stackpack. It's even the same color. The only difference is mine has a small Doyle logo on it near the mast on both sides.
1979 Gulfstar 37 Laissez Faire
Reefing with a Stack-Pack? KeelHaulin General Discussion (sailing related) 8 05-12-2010 10:56 AM
Stack Pack advice? MedSailor Gear & Maintenance 9 03-24-2010 07:53 PM
Boom Furler sailor50 Gear & Maintenance 3 08-28-2009 09:47 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
STACK PACK/SAILS asilverman Gear & Maintenance 1 08-30-2001 09:59 PM
