11-23-2010
Here's what I find works well and I've done a bunch of them:
1. Drill into the center of the plug with a small bit---maybe 6/64 or 3/32. The bit will hit the phililps head under the plug, so drill carefully and you won't hurt anything. Sooner or later, you'll snap off the bit--the price of doing business.
2. Put a phillips head bit in your dril and screw a drywall screw slowly into the hole you just drilled. The drywall screw will bottom on the hidden screw head, and its continuing turns will draw the plug out.
3. Dig any remaining pieces out with an awl or other narrow, sharp tool, being careful not to gouge the edges of the plug-hole.
Sounds involved, but once you've done a half dozen or so, you can pop them right out. Half of them come out in pieces, but they were originally held in with a drop of varnish, so the chunks pop out easily.
I've taken up & remounted the teak and holly floor on my 33 footer, and done lots of work on interior and exterior teak and this is the method that works for me.
John V.
