Old 11-23-2010
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
Bottom Job Questions
I began scrapping the old anti fouling paint off the bottom today. I'm not going to do the bottom job til spring but couldn't help asking a few questions now.
Under the anti fouling paint is a layer of very hard gray colored paint. I assume it's a barrier coat because underneath this layer is the white gelcoat. The gray layer is extremely hard to remove.
I plan on doing a new barrier coat in the spring. Can a new barrier coat be applied over top of the old coat or does the old coat need to be removed?? I should also mention that there are spots where blisters between the barrier coat and the gelcoat popped up.
The keel has some issues I think. In some spots a very light scraping exposed lead. The gelcoat was extremely thin. Should the lead be sealed up before putting the barrier coat on?? If so, what method is recommended??
Thanks!
My complete refit is taking completely too long!
Old 11-23-2010
Yes, you can barrier coat over the old barrier coat. There is no need to scrape down to the gelcoat.
In the areas where the blisters are, you should sand the blisters away and then clean the hull there thoroughly, let it dry out over the winter and then re-barrier coat the area before bottom painting the boat. These are likely not osmotic blisters, but rather blisters formed over places the hull wasn't properly prepped.
The lead should be sealed using a barrier coat or epoxy.
Old 11-23-2010
Hey Sailingdog!
Thanks! I have another question...haha. I bought the 3M Premium Filler and haven't used it yet. Can the filler be used over top of the barrier coat or will I have to apply it to fiberglass?
Old 11-23-2010
I wouldn't use the 3M premium filler. It is a vinylester resin, and as such has a fairly weak secondary (adhesive) bonding characteristic. I'd use thickened epoxy instead. Use cabosil or fumed silica as the filler.
Old 11-23-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Whatever filler ya use, apply it directly to the glass.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Bottom strip/paint questions tip Gear & Maintenance 22 05-26-2010 10:37 AM
Would Love Your Thoughts on Specific Barrier & Bottom Job Questions BugsBunny Gear & Maintenance 15 05-31-2009 10:44 AM
Bottom Paint Questions harbin2 Gear & Maintenance 8 02-22-2009 12:09 PM
Winter Bottom Painting Questions cosmoking Gear & Maintenance 3 12-12-2008 07:29 PM
Questions: Bottom paint prep work for trailer boat venturousviking Gear & Maintenance 22 04-23-2008 10:48 AM
